Removable Top Bolts?
Old 10-01-2007, 11:48 AM
PioneerPete's Avatar
Question Removable Top Bolts?
I've got an '88 4runner and I took the top off for summer and somehow lost the bolts. I have checked the local juckyards and no one has an old 4runner. Any advice on finding new ones? Are they bolts that I might find in a hardware store? Measurements?
I live in Wisconsin and its getting a little chilly for the no top thing.
Old 10-01-2007, 11:54 AM
88wildrunner's Avatar
do to a dealer ship and buy one, then go to a large autoparts store, like napa and they should be able to match the bolt with their stock of fastners.
Old 10-01-2007, 12:33 PM
Thanks. I'll give it a shot.
Old 10-01-2007, 12:38 PM
OSU4Runner's Avatar
I have like 6 bolts from the top of a 89 4runner if you want them!
Old 10-01-2007, 05:34 PM
bob200587's Avatar
The head is 14mm....I know that much.
Old 10-01-2007, 05:40 PM
slacker's Avatar
actually 12mm heads ..
bolts are sized 8mm X 1.25 X 30mm and should be avaliable at any hardware store .
There is one bolt on the drivers side , second from rear , that actuates a swithch for the rear door .. make sure it connects , or your rear window wont work .
Old 10-01-2007, 06:34 PM
just a 22re's Avatar
i live in wis to were you at?
Old 10-01-2007, 07:35 PM
I'm in school at UW-Platteville. U?
Old 10-02-2007, 07:00 AM
kcrunner's Avatar
I concure.
Old 10-02-2007, 07:07 AM
04 Rocko Taco's Avatar
X2. There are 14 (fourteen) bolts in the top. But they are 12 (twelve) mm.
12mm also does the doors.
Old 10-02-2007, 07:25 AM
Djlarroc's Avatar
You can take all kindsa stuff apart on those Runners with a 10 & 12 MM tool.
Old 10-02-2007, 08:31 AM
4Crawler's Avatar
Sizes as noted on the web page below:
- http://www.4crawler.com/4x4/4R_TechI...opInstallation
Old 10-02-2007, 08:39 AM
waskillywabbit's Avatar
The bolts are M8-1.25x35mm as bolts are sized by the diameter of the bolt shaft...not the head (or size socket you use to remove them).
You do use a 12mm socket to remove the M8-1.25x35mm bolts.
09-04-2015 09:27 AM
Iceman4193
07-15-2015 04:48 PM
Cdn-wilderness
07-10-2015 07:43 PM
crashburnoveride
07-10-2015 06:39 AM
Snort
07-09-2015 03:58 PM
Quick Reply: Removable Top Bolts?
