Remote start - Heater & controls do not when remote started?
Old 11-25-2010, 07:47 PM
LifterCatcher's Avatar
Remote start - Heater & controls do not work when remote started?
Well I just finished installing a relay for the clutch switch so that the remote start system will work. Everything works fine the truck remote starts without a problem and runs.
However the heater/blower and the majority of the center console does not work when the truck is remote started. It seems that the key has to be in the "ON" position for the heater and gauges to work? I am so pissed at the moment, what is the point of having a remote start if you cannot run the heater?
The system is a Ultra start 2256M (made for manual vehicles) does anyone else have this issue?
Thanks
Old 11-25-2010, 08:13 PM
Originally Posted by razed
the system is only applying power to the ecu and ignition and switching the starter on.
you'd need to wire another relay in parallel to the ignition switch to apply power to the rest of the electrical system
On the main connector there is a white wire that is a "6-WHITE Selectable Output - Output for 2nd IGNITION, 2nd
ACCESSORY or 2nd STARTER." Can I just hook this wire up to a wire that is powered in the "ON" posistion? will this fix the problem, currently the second ignition white wire is not hooked up.
Old 11-25-2010, 09:10 PM
Ok well I went back and went over everything again and also compared all the alarm wires to 12volt.com and I had the alarm blue wire hooked up to the trucks 2nd ingnition source(black/red wire). So I moved the alarms blue wire to the trucks primary ignition source (black/yellow) and I hooked up the white wire to the 2nd ignition source (black/red) However I did not move the jumper I left it alone. It all works great now.
I must have read the jumper part wrong, I thought if you moved the jumper it would send the output to the 2nd ignition source first instead of the first ignition source.
Should I disconnect the white wire?
Thanks for all of your help
Old 11-25-2010, 09:25 PM
Ok thanks ya it works, but dont want it to catch fire or something LOL. the directions are very vague and kinda a PITA to use.
Thanks for your help.
Charecter1
11-06-2023 10:08 AM
raiderhawks00
07-08-2015 06:23 PM
Huntingtruckcletus
07-08-2015 05:26 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Remote start - Heater & controls do not when remote started?
