reman flywheel balance
doing a reman.
manual sez to mark flywheel to crank reference. I assume this has something to do with balance.
since the old block is gone, i have no reference alignment for the flywheel on the remanufactured engine.
just bolt it on and hope for the best, or, is there a reference while reman is @ TDC?
any expertise out there would be appreciated.
thanx
thanx
I'll have to check on it only going on one way when i get it off the engine stand next week.
I have since found the orientation of my flywheel with respect to TDC on the original block. (I took a lot of pictures). It shouldn't be a problem lining the flywheel up with TDC on the reman.
thanx for the reply!
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
