relocating transfer case oil cooler
Old 09-03-2014, 11:43 AM
nortonian's Avatar
I have a '95 3vze with a 2" OME lift and Doug Thorley headers. When I had the headers and cat back exhaust installed the muffler shop relocated my transfer case oil cooler because it interfered with the exhaust. Now its welded to the bottom of the frame. I'd like to move it higher but the oil lines are too short to get it anywhere, and they're 20 years old so I wouldn't mind changing them out for new longer ones. Problem is, the oil cooler is no longer available and I can't find longer lines with the metric banjo fittings.
Has anyone else had to replace or move this and if so how have you done it?
Old 09-04-2014, 08:52 PM
nv4runner's Avatar
I recently replaced an engine in a dump truck and needed a new oil feed line for the air compressor. Took the old broken hose to a hydraulic shop and had a new one made. Call a shop and see if they have the banjo fittings or can get them.
Old 09-05-2014, 11:53 AM
nortonian's Avatar
I tried one place that makes hydraulic lines and they said they couldn't do it. I guess I probably would need a noes cooler too since the old one was welded directly onto the frame. It's ok where it is for now but I'll have to keep looking.
Old 09-05-2014, 08:42 PM
nv4runner's Avatar
You could always cut it off of the frame when you are ready to move it and either weld it back on or have some brackets welded on if there isn't room to drill holes for bolts. Maybe there are already bolt holes in the cooler. I've never noticed one on my 4runner. I'll have to take a look sometime.
Old 09-07-2014, 02:01 PM
nortonian's Avatar
found a DIY junk yard with 2 2nd gen 4runners. Pulled the cooler, bracket and lines off the one that looked in best condition. This will go on my list of future projects.
Also saw they had some wheels. I want one to use with a spare. I'll have to go back next saturday.
Tykiller1994
08-10-2015 07:49 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
Coreyr384
07-10-2015 11:13 AM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: relocating transfer case oil cooler
