refill gear oil through shifter?
This is a pretty straightforward question. Can you refill the gear oil through the shifter hole once the stick is removed? Or does it have to be done through the filler hole on the size of the t-case and transmission? I was able to do this on my suzuki sidekick.
Hey boys,
So you can fill thru the hole your shifter screws into but how will you check the level? How do you know you're putting the right amount in there?
Signed,
Goin' thru the fill hole in Virginia. :-)
Signed,
OR!!!!!!!!! Take the fill plug out of the tranny. When it's full, it will pour out. Just keep a clean, clean, clean container under the tranny to catch the spill so no waste, eh.
That's pretty much all i was looking for. thanks.
Hehehe......it's the simple things that sometimes elude us in life.
Then again, it does help to know the fluid capacity.
strange... I would think it would just be easier to put a wrench on the fill plug and fill it up there...
unless the plug's rounded off...
or broken off in the tans...
but who does that
but who does that
You can also fill your T-case through the T-case shifter on top shift cases. Since yours is a forward shift case, you will have to fill your case through the back.
XtraCab
04-12-2020 05:25 AM
Iceman4193
07-15-2015 04:48 PM
Jnkml
07-06-2015 01:20 PM
