Red and white wires off distributor
Does anyone know which wire is the positive and negative off a 1986 carb'd 22r distributor. I'm installing an MSD 6A and don't know how to test the polarity of the magnetic pickup. Thanks!
sorry, i should of been clearer. the igniter is broken. i am trying to use the magnetic pickup in the distributor to trigger the 6A. Which wires hook up to the green and violet off the msd?
courtesy of
MSD 6A without ignitor:
Heavy red wire = Battery 12V +
Heavy black wire = Ground
Small red wire = switched 12V (beige wire originally to ignitor)
Small white wire = NOT USED (make sure it won't ground on body)
Small purple wire = violet wire from distributor
Small green wire = white wire from distributor
Small orange wire = + side of coil
Small black wire = - side of coil
the1998sr5
15
07-14-2020 08:35 PM
montanatruck
02-26-2017 07:07 AM
steve miller
10-10-2015 01:40 AM
