Recomended 3.0 head gasket?
Old 09-07-2010, 06:43 PM
Sansocal
Guest
Posts: n/a
Cool Recomended 3.0 head gasket?
I have to replace my head gasket on my 92 truck, with the 3vz-e. What is the best head gasket kit that isn't going to blow up on me (engine has had 2 gaskets already) I have seen regular OEM gaskets, Fel-Pro, multi layer steel, and copper gaskets..
Old 09-07-2010, 06:53 PM
yotaman85's Avatar
Oem....
Old 09-07-2010, 06:56 PM
#1Grunt's Avatar
Stay AWAY from fAIL-Pro crappy GASKETS. OEM is the way we go, or you could check out DOA motorsports they got some pretty hard core parts,expensive but good.
Old 09-07-2010, 07:19 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
The most expensive one I could find...
Wonder if Cometic makes one?
nope
well that sucks... http://www.cometic.com/sportcompact.aspx
Old 09-08-2010, 11:04 AM
MudHippy's Avatar
See my thread on 3vze head gaskets, specifically post #16, for my recommendations.
https://www.yotatech.com/forums/f123...askets-191393/
Old 09-25-2010, 10:53 PM
Casey320's Avatar
Check mytoyota to see if it is recall worthy. As far as gaskets, I can't tell you. I'll find out which ones my first mechanic used, or didn't use, and you can avoid them. Just had mine replaced last week and the mechanic said there are no signs of the engine ever being apart. Just tighten the headbolts and charge yourself $700 for doing so. Good luck on set #3 for ya!
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Recomended 3.0 head gasket?
