| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | |||||
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." |
#27 (permalink) | |
Quote:
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#28 (permalink) |
right now im trying to get the internals out of the larger part of the hub. Everything slides, and ALMOST comes out..but just wont come all the way. I guess its the spring gear
__________________
86 Ext. Cab Pickup 7 inches of lift/36 inch Wild Countrys Buick 3800 V6. Performance intake manifold,holley carb,Cam,headers,MSD ignition,dual exhaust Last edited by Tacoma750; 10-23-2007 at 10:15 PM. |
#29 (permalink) |
Yeah where Jays link says "this is where it gets tricky" they aren't kidding. Getting that clutch, tensioner spring and follower pawl together right is a real PITA. That spring just doesn't want to stay put.
__________________
86 4Runner, custom Sonoran Steel rear bumper, 4Crawler 1" body lift, rock sliders from Richard Stubbs, rear Lockright, SAS w/ARB My build thread. http://www.yotatech.com/f66/blknblu-s-sac-155872/ |
#30 (permalink) |
Staff
Have you talked to Brian? (WaskillyWabbit, owns WabFab) he sells these things rebuilt on his website and ready to bolt on!
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#31 (permalink) |
yeah man ^ The hardest part was getting the spring into the gear and attached to the other spring... and grease just makes it worse!
Back to helping Now where you able to get the outer bigger gear out? It should slide out without a problem, but in any case, it needs to come out to get everything working.
__________________
#32 (permalink) |
persistance! I got it out..I have them all pretty much torn down! thanks so much for your help fellas. Here you will see what im left with. I got the gear out, and you can see whats left in the hub. does that HAVE to come out?
__________________
86 Ext. Cab Pickup 7 inches of lift/36 inch Wild Countrys Buick 3800 V6. Performance intake manifold,holley carb,Cam,headers,MSD ignition,dual exhaust |
#33 (permalink) |
Awsume!
Okay, no that bottom gear does not have to come out. Thats the gear that will "lock" things in place. now just clean out as much as that old grease as possible, I used water and a toothbrush with plenty of rags handy. you will see a groove cut into the gear on the inside, thats what that smaller spring winds into to hold onto it.
__________________
#34 (permalink) |
these things are darn near bone dry inside. Im gonna finish tearin them down and tomorrow soak them in degreaser. Is that a safe thing to do?
Also..I only have ONE of these.
__________________
#35 (permalink) |
Well I wouldnt soak the dial in any cemicles since it has a rubber o-ring in it.
Now you only have 1 spring, you need 2.
__________________
#36 (permalink) |
I let mine sit for a week in mineral spirits then cleaned them out and off not the dial though I took it apart and removed the O ring before soaking it.
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." Last edited by CyMoN; 10-23-2007 at 10:30 PM. |
#37 (permalink) |
Well im not concerned about gaskets and orings. IM gonna order the rebuild kit from DOWNEY. Its like $21, plus it has the nice screws to put them back together..i dont have any screws as of now.
Where can I get another of those springs?
__________________
#38 (permalink) |
Yeah for $250!! I'll take a crack at rebuilding thanks.
__________________
#39 (permalink) |
^^ exactly...I like to try to rebuild stuff..its fun. SO after a little time and help form you all...here is what I have siting infront of me
__________________
#40 (permalink) | |
Quote:
You can get the bolts at any hardwear store, I got mine from a place near my house.. M16x6 bolts im pretty sure. But as far as I know you can't really buy it online, you MIGHT be able to get one from the dealership but it might be one of those things you need to go to the wreckers for.
__________________
#41 (permalink) |
That may be a tough one. I'd say try the dealer.
__________________
#42 (permalink) |
i'll check the hardware store..I need all the gaskets and everythnig anyway. there are NONE in my hubs now. So the downey kit would be agood i think...now i gota try to find this darn spring. Whats that called? or is there a part #?
__________________
#43 (permalink) |
It looks like there is a spring attached to the Big spring on the left of your pic, or is it just the angle
__________________
#44 (permalink) |
^^ DUDE!!! yuor the flippin MAN haha. Your right, it was there. I just popped it off. Now i have all the parts. Just need to track down all the gaskets/orings
__________________
#45 (permalink) |
Haha, sounds great!! Now you see how the spring clips into the bigger spring, now you just need to thread the end of the little spring into the gear
__________________
#46 (permalink) |
yea, but i'll attempt that after I clean everything. Tomorrow i'll track down some snap ring pliers and take the dial apart. BEING EXTRA careful not to loose that ball that eevrybody talks about. THan im gonna scuff em up and paint them.
__________________
#47 (permalink) |
Good stuff, going with hammered grey?
![]() And that little ball, mine simply slid out due to grease, but I have heard of them "shooting" out.
__________________
#48 (permalink) |
I dont know about hammered grey. My wheels are hammered grey, and I think I want the hubs to stand out a little. IM gonna leave the dials red, like they are stock. But im not sure about the rest. I MIGHT go with a silver color.
__________________
#49 (permalink) |
im lookin arund for how other people have painted there hubs..other tha OEM colors
__________________
#50 (permalink) |
You should match the dial colour to your body paint. Thats what I did with mine
Gives it that suttle touch
__________________
| Tags |
| hubs, manual, taking, warn |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| WabFab Off-Road Auto Hubs to Manual Hubs Conversion Kits | waskillywabbit | Vendor Advertising | 0 | 03-16-2007 06:58 PM |
| Rebuilding aisin hubs | 1Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 24 | 06-16-2006 07:30 AM |
| Rebuilding ifs asian hubs | van7559 | 86-95 Trucks & 4Runners | 4 | 05-30-2006 08:08 PM |
| Are ADD hubs pretty much just manual hubs that are always locked? | GradSR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 29 | 11-14-2005 12:02 PM |
| I need help with rebuilding the aisin manual locking hubs for 86-95 IFS | byron4 | Offroad Tech | 22 | 04-10-2005 08:09 PM |
