Rear window relay fix- 1990 4Runner - Page 3 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-27-2008, 02:55 PM   #51 (permalink)
Matt16's Avatar
Bump, I need an answer. I don't want to buy a new motor just to find out thats isn't the problem.
Are they're any fuseable links in the system?
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 10-27-2008, 04:05 PM   #52 (permalink)
Hophead's Avatar
HEy Matt - the only advice I can give you is that I think the problem is not with VOLTAGE rather its AMPERAGE. AS the motor gets older its current draw increases - I would think that the factory circuit can only supply a limited amount of current. As the window nears the top of the run it is asking the most work form the motro which in turn is looking for more current which teh factory circuit can not supply. Hence it works fine jumped straight from the battery. My reasoning is based on my expirence with my fuel pump- it would not run through the factory circuits but run fine when jumped straight from the battery. I replaced the pump and the new one runs fine through the factory circuit.
I am by no means an electrical guru ( FAR friom it)
Have you tried removing the motor and having a look inside - mine was rusty and obviously not in the best shape. I cleaned it up and reinstalled it - so far no problems...
Hope this helps.
__________________
1992 4Runner - 3.4 Swapped, stuff.
Hophead is offline
Old 10-27-2008, 04:11 PM   #53 (permalink)
Matt16's Avatar
Hope this helps.
Hmm. Interesting, I didn't know it could draw more amperage as it wore down.
As a side note, what actually wears out in an electric motor???
My runners are kind of rusty, but well greased now. I didn't think you could buy new runners though. The gears for the scissor mechanism look fine.
__________________
Toyota FAQ link
Matt16 is offline
Old 10-27-2008, 06:47 PM   #54 (permalink)
Hophead's Avatar
When I took my motor apart I found that there had deffenitely been water or moisture inside the motor - the bearing/bushings inside were pitted and rusty. I cleaned and sanded smooth all the bearing/bushing surfaces and lube it up with dialectric grease. I also cleaned and shined up any electrical point/contacts. Not saying this will be the answer but worth a shot.
ASfor motors requiring more current draw- you can imagine if all the bearings are rough and it is hard to turn the "thingy'" (STATOR??) around in the feild it will requre more current . Very technical description I know!
Might just need a new motor. It would be nice to measure the current draw at the motor and compare it to a new/ working motor.
__________________
Hophead is offline
Old 10-27-2008, 07:31 PM   #55 (permalink)
Matt16's Avatar
Lubed up the runners, this time with silicone spray (as opposed to grease) and WOW, it moves. Doesn't even slow down near the top.
Maybe I'll pull out the motor sometime and have a look at the bushings. Anyone know if they're rebuildible (the motors that is)?
__________________
Toyota FAQ link
Matt16 is offline
Old 10-27-2008, 07:42 PM   #56 (permalink)
Hophead's Avatar
Nice! I always use silcone spray on the window tracks. When I used white lithuim grease it just seemed like a magnet for crap. Glad that worked out for ya.
__________________
Hophead is offline
Old 10-27-2008, 07:53 PM   #57 (permalink)
Matt16's Avatar
I got some weird looks from the girl at one of the shops I visited when I asked about silicone lube. Apparently, there are multiple types of silicone lube.
This is what you want:
This isn't:
__________________
Toyota FAQ link
Matt16 is offline
Old 02-04-2009, 06:12 PM   #58 (permalink)
90
90's Avatar
Thanks for the writeup! Main Electronics had the same relay in stock ( I live in Vancouver ) and I had my first ever desolder/solder job under my belt, along with a gate window that responds! woot
__________________
"Whiskey is for drinking. Water is for fighting over."- Mark Twain
90 is offline
Old 02-04-2009, 08:00 PM   #59 (permalink)
Matt16's Avatar
Quote:
I think that very well may be the same store I bought mine from. I'm in N Van. Glad it worked.
__________________
Toyota FAQ link
Matt16 is offline
Old 02-08-2009, 02:37 PM   #60 (permalink)
well i dont know if youve looked at a wiring diagram for the back window. I found out that on it there is a power window limit switch. i looked at a wiring diagram to find out the other realys on the circuit board for but nothing yet, but look at the circuit, according to diagram in the right side bottom part if you look up a bit youll see a power window limit switch. that may be what causes your window to go up so fast when you go direct with battery. heres a link at the bottom you may have to copy paste it. and youll have to zoom in to make it more clearer.
http://www.ondemand5.com/mric/common...&COURTESYTAG=&
marshm4ll0w is offline
Old 02-08-2009, 03:52 PM   #61 (permalink)
Matt16's Avatar
I'm only getting a white blank page when I open that link. What do you think the purpose of the power limiting switch is? Think I could/ should I bypass it?
__________________
Toyota FAQ link
Matt16 is offline
Old 02-08-2009, 04:46 PM   #62 (permalink)
you could bypass it probally, although it may be just incase the motor gets to much power. like a fuse kinda idea, its probally like an inline reisistor id guess, or similar idea. personally id just leave it alone and keep it wired in, providing your window actually works. its not like it has to go up speedy fast as long as it goes all the way up and down id say id be happy, mine doesnt work at all. i played aorund with the box and it started to half work which was good news for me. that link works for me though, im not sure why it doesnt work for you. have you tried to zoom in? like at the top theres a toolbar and you can click the magnifying glass a few times and it all comes in clear.
Old 02-08-2009, 04:50 PM   #63 (permalink)
oh and you said you got it form vancouver? i live in mission, and was wondering what the store was called id like to call and maybe go and pick some up, everywhere iv looked so far has no idea what im looking for. im gonna try this other guy he does auto electrical i was told he would be good to get in touch with.
so i went down to radio shack which is now the source/ circuit city and asked for a relay and the lady was like whats a relay. and i thought to myself no one has any idea what things are anymore.
Old 02-08-2009, 06:24 PM   #64 (permalink)
Matt16's Avatar
http://www.mainelectronics.com/
__________________
Toyota FAQ link
Matt16 is offline
Old 02-08-2009, 09:04 PM   #65 (permalink)
right on thanks. im taking out the 2 realys right now. was earlier. its actually harder than i thought it would be. iv taking the solder off of the 5 pins on one
but i cant seem to get it off the board still. is there a trick to getting it off? maybe i neeed to take more solder off.
Old 02-08-2009, 09:46 PM   #66 (permalink)
nevermind i got them now. thanks for the thread.
Old 02-08-2009, 09:52 PM   #67 (permalink)
Matt16's Avatar
A solder sucker works well, its basically a spring loaded syringe that you "fire" when the solder is still hot.
__________________
Toyota FAQ link
Matt16 is offline
Old 03-09-2009, 11:40 AM   #68 (permalink)
JohnRaven's Avatar
QUESTION:
Here's the situation...
My rear window went down about an inch all by itself yesterday.
I took the back panel off to jump the motor to close the window.
I just took the relay box out, however... Before I start replacing relays, how do I KNOW they are bad??? Is there something else that COULD be causing the problem?
JohnRaven is offline
Old 03-10-2009, 09:54 AM   #69 (permalink)
JohnRaven's Avatar
Bueller, bueller?
Old 03-13-2009, 10:47 AM   #70 (permalink)
JohnRaven's Avatar
Anyone?
Old 03-13-2009, 02:05 PM   #71 (permalink)
Matt16's Avatar
Replace all relays
__________________
Toyota FAQ link
Matt16 is offline
Old 03-14-2009, 05:16 PM   #72 (permalink)
JohnRaven's Avatar
Are they all the same??? Can they all be replaced by the same relay? IE this one?
http://search.digikey.com/scripts/Dk...me=255-2080-ND
Old 03-14-2009, 05:25 PM   #73 (permalink)
Matt16's Avatar
They are all the same relay.
__________________
Toyota FAQ link
Matt16 is offline
Old 03-14-2009, 05:44 PM   #74 (permalink)
JohnRaven's Avatar
Thank you!!!
Tags
1990, 2005, 4runner, 86, back, fix, motor, power, rear, relay, remote, setup, toyota, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
92 4runner Relay (rear Window) CHIBA The Classifieds GraveYard 13 01-08-2008 02:39 PM
'93 4runner rear window/wiper relay. SAMI188 86-95 Trucks & 4Runners 2 01-18-2007 08:36 PM
FS: Toyota 4runner Rear Window Relay 92 93 94 95 CDUFF7 The Classifieds GraveYard 4 08-11-2006 05:38 PM
87 4Runner rear window relay mind of its own colsoncj 95.5-2004 Tacomas & 96-2002 4Runners 3 12-05-2005 09:31 PM
2009 InternetBrands, Inc.
