| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
rear window
#2 (permalink) |
You don't mention year or condition of tailgate. Do you even hear the motor "whirrr"? Is the idiot light on on the dash? Do you hear the warning beeper when using the inside switch (not sure if this beeper works on the key as my cylinder is toast).
Due to the condition of my tailgate my window comes out of the scissor mechanism, I can still hear the motor work though, it's just a matter of getting the window back in the mount from time to time. Ohhh yah, do you hear the relay click inside the rear quarter?
__________________
92 'Runner Medalist Edition 4Crawler 2" Body Lift | 4Crawler 1 1/2" Ball Joint Spacers | 4Crawler 1" diff drop | 26mm Downey Torsion Bars | 4Crawler Pan Hard bar drop | FZJ80 Coils | Skyjacker Nitro's | 33x12.50 Interco TruXus MT's President Ottawa Valley Offroaders http://ovo.ca |
#3 (permalink) |
Yea, listen for the relay. Most common place is in the side panel behind the driver or rear, driver's side passenger. Check your wiring between the body and tailgate - common place for pinches and corrosion. Pull the cover off the tailgate and check for corrosion.
__________________
89 4Runner, V6, Auto, Some stuff's stock, some's not. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rear speakers Above Rear window 2nd Generation | AJwhoisthat | Vehicle Audio & Home Entertainment | 9 | 07-24-2006 01:43 PM |
| Rear Window | Sleeper | General Electrical & Lighting Related Topics | 3 | 12-21-2005 07:49 PM |
| Help with rear window : it's loose in the rear hatch! | Hugo | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-25-2005 10:28 AM |
| Rear window | 92foreruner | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 01-05-2005 12:43 AM |
| Solid Rear Window/Sliding Rear Window Trade | MorphiasX | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-23-2004 09:18 PM |
