rear window
I had to go through the same thing with my runner and this is what I did to get the window down to replace the motor. The problem with these windows most of the time is the gear on the motor gets stripped, so the motor runs but the window doesnt move. First you need to take off all of the paneling on the tailgate, which should be pretty easy. Next if you look inside you will see the motor that moves the window and two arms that connect to the left and the right of the bottom of the window, with a screw driver or something of the sort try to pull or pry the arms downward to help the window move while having some one else push the window button down. If you want to replace the motor then you need to get the window low enough to get the arms to be completly horizontal and pull one off of each side of the track of the window at a time and then the window will slide right out of the tail gate. You then need to remove the screws holding the motor in place and then replace it and put the window back the same way you took it out. When i first checked at a window place they wanted around $200 to replace the motor, but I had a buddy of mine get me a refurbished motor for $35 and changed it out this way and saved a ton of money. Also if you get a refurbished motor, most places that fix them will buy your broken one for $10 or so. I would recommend replacing the motor, it is really simple, but if you just want it down you can try and just pull the window down from the outside while having someone push the button, you can do this without taking anything off. Sorry I dont have any pics, but I hope this helps you.
you can get at the motor without having to remove the glass. in fact, its much easier with the window in the up position. there are three bolts that you remove and the motor will come out after you unplug the wires.
you can then manually operate the window, this would be a good time to check and lube the mechanism.
lee
lee
actually, i need one more clarification, working at a summer camp in maine for the past 6 weeks interupted any plans of working on the grey beast, is it possible to get the trim peices off with the tailgate up?
yes you can pull the panels off with the tail gate up or down or in between. The first panel you can just pry right out they are held in by plastic rivets. You can use you hands to pull it off the panel is held on with about 8 or 10 plastic rivets, they are all along the edges of the panel, if you use your hands be careful take your time due to the fact the panel is made out of a fiberboard it breaks easily if your rough with it. another way to get it off is use a flat head screw driver and slowly pry it up unless you have that special plastic rivet tool, snap-on makes a really nice one. after you get the first panel off then under it is another panel/ acess panel what ever you want to call it. It is held on with about 6 phillpips screw pull it off then you should see the motor right there. And you also might have a layer of plastic to help protect against the glass in b/w there. just pull it off cut it what ever you want. I never put mine back on i saw it kinda pointless to put back on
Most of the time it is not the motor that "dies":
- http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
06-01-2021 01:51 PM
sabine
07-18-2015 03:59 PM
icentropy
07-14-2015 10:23 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
