rear tires wearing weird axel help?
Old 11-02-2007, 08:54 PM
skife's Avatar
my rear tires are wearing real bad on the insides and look brand new on the outsides, anyone got any idea whats wrong with the truck?
thanks
justin
Old 11-02-2007, 08:55 PM
sh0kk86's Avatar
what psi?
Old 11-02-2007, 08:58 PM
1eye's Avatar
Bent rear axle housing?
Old 11-02-2007, 09:01 PM
4Crawler's Avatar
If the rear axle, you might try measuring the front and back tire width (measure from tire to tire across the front and back of the tires) and see if there is any toe in (or out), possibly due to a bent axle housing. You should measure no difference between the same part of the tire front to back. Or you could run a string along both sides of the truck, having it just touch the sides of the rear tire and see where the strings line up (should be parallel). Also, might be a camber issue (again due to a bent housing). Use an angle finder or square to check that the rear wheels sit perfectly vertical.
Old 11-03-2007, 08:56 AM
skife's Avatar
Originally Posted by sh0kk86
what psi?
both rear tires are between 35-40 psi
max on them is 50
i've already ruled that one out.
Old 11-04-2007, 07:09 PM
skife's Avatar
axel bearings are toast.
there is a ton of slop in them
BushPig
10-29-2022 06:26 AM
06-01-2021 01:51 PM
djpg2000
11-11-2020 04:56 AM
icentropy
07-14-2015 10:23 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: rear tires wearing weird axel help?
