Rear sway bar bolts sheared
Old 04-10-2008, 12:28 AM
Matt16's Avatar
I was replacing the SB bushings and all 4 of the bolts holding the SB to the rear axle have sheared off while trying to remove them. I think at some point some mechanic used crap bolts and replaced the Toyota one's. I've had the occasional bolt break, but this is ridiculous.
How would you guys go about removing the bolts. The heads sheared off flush with the mounting bracket...bugger.
Old 04-10-2008, 01:15 AM
mjwalfredo's Avatar
This one was a bugger for sure when it happened to me a few months back.
I would first try an "easy out" to see if you can remove the bolt.
For me, that did not work too well, mostly because it was my first time using one. Sounds like it might be your first time too.
Since the easy out didn't work for me, first, I had to drill through the sheared bolt. Next I took a dremel and a cut off wheel to cut off the captive nut on the back side of the mounting tab.
I couldn't cut all of the captive nut so I then used a screw driver as a chisel to chisel the rest off.
Then I had the pleasure of using a replacement nut and bolt to hold the swaybar on to my newly deformed mounting tabs. It was a bitch to hold the nut in place now that the captive nut is gone.
I really hope an easy out works for you. Make sure to soak the broken stud in PB blaster really well before you attempt the easy out and good luck!
P.S. My bolts were Toyota bolts that sheared. If you ever replace rear sway bar bushings again in the future, make sure the bar is supported well so there are no undue forces on the bolts while you are loosening them...
Old 04-10-2008, 04:39 AM
itsmeagain5789's Avatar
sorry for the hijack, but whats the advantage for removin the swaybar? more flex?
Old 04-10-2008, 04:51 AM
dirtoyboy's Avatar
easy! Remove swaybar. Throw in trash. Done!
Old 04-10-2008, 05:42 AM
mjwalfredo's Avatar
Well according to Matt's post, he was replacing the bushings so that's why he had to remove his sway bar. The can wear out and eventually split after a long time.
A lot of people remove it completely for the added flex. They swear that it doesn't make much of a difference in handling because the rear sway bar is not as important as the front.
I had mine off for a little while but put it back on because I did notice a difference in handling...
Old 04-10-2008, 09:01 AM
Matt16's Avatar
It makes a little difference in handling, its not uncomfortable without it though. I want to re-install mine because with it off, the rear flexes too easily and thus the front IFS isn't forced to flex off road.
Old 04-10-2008, 10:38 AM
dirtoyboy's Avatar
take them both off....
Old 04-10-2008, 12:32 PM
Matt16's Avatar
How did I know that was coming. Seriously though. I think the swaybar in the rear helps (forces) the front to flex. That is why I don't want it removed.
Old 04-11-2008, 10:29 PM
n16ht5's Avatar
but picture the green guy as your swaybar
Old 04-12-2008, 01:30 AM
Matt16's Avatar
Is it not the case that the rear coils are much flexier than the T-bars? Thus, to get the front to flex, the rear sway bar helps, by not allowing the rear to easily flex.
Old 04-12-2008, 07:41 AM
n16ht5's Avatar
thats true, but can you get your rear to flex all the way with it? my t bars flex all the way in the front fine wihtout any SB
Old 04-12-2008, 10:06 AM
Matt16's Avatar
The rear sway bar looks about half as beefy as the rear. I don't think it does much beyond help the front flex.
oldirtydirt
02-23-2020 09:30 AM
09-04-2015 09:27 AM
DrZero
18
07-24-2015 11:31 PM
Iceman4193
07-15-2015 04:48 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Rear sway bar bolts sheared
