rear pumpkin install. stuck partway - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-24-2009, 03:23 PM   #1 (permalink)
mojo4x420's Avatar
I bought a used pumpkin from a 2nd gen 4runner. 4.56 gears. I am currently trying to install into my friends 88 4runner.
I've done this a couple times before w/ not problems.I did the same thing to my 89 4runner.
This time, when everything went back together, the passenger axle isn't going in all the way. There's about a 1/4 inch of space between the backing plate and the axle. It feels like it's hitting something in the diff. axle is engaged w/ the gears and working, just seems like a large gap.
Drivers side went back in w/ no problem.
Any suggestions? I'm going to try tightening down the bolts to see if everything pulls together easily, but it seems like there's more of a gap then there should be.
cheers.
__________________
89 runner - 22re, chevy rear leafs, ball joint spacers, 4.56 gears, 31x10.5xr15
mojo4x420 is offline
Old 02-24-2009, 03:58 PM   #2 (permalink)
iamsuperbleeder's Avatar
Send a message via MSN to iamsuperbleeder Send a message via Yahoo to iamsuperbleeder
maybe you need one of these
haha
I dunno buddy, the other side's going in fine?
try pulling the axle shaft back out of engagment from the spider and turn it a little and try to slide it back in? I dunno... that's stange...
same old axle shafts, backing plates, and rear wheel bearings?
iamsuperbleeder is offline
Old 02-24-2009, 04:00 PM   #3 (permalink)
mojo4x420's Avatar
Only thing changed was the diff.
__________________
Old 02-24-2009, 04:15 PM   #4 (permalink)
Quote:
complete assymbled 3rd member swap, right? no fooling around with the gears? all stock gears? (by stock I mean stock for whatever Toyota the came out of... their not after market gears, no locker, or anything)
Old 02-24-2009, 04:26 PM   #5 (permalink)
jjrgr21's Avatar
mine did the same thing on drivers, 2x4 block, and a mini sledge
__________________
2003 4WD TRD Tacoma
1986 4Runner
jjrgr21 is offline
Old 02-24-2009, 04:30 PM   #6 (permalink)
mojo4x420's Avatar
I didn't see a locker. Gears should be stock toyota gears, but I didn't look that close.
I tightened the backing plate up and the gap closed up fine.
Looks like everything is good. I'll post to confirm everything's still good after a fluid fill and a test drive.
Thanks for reads and replies!
__________________
Old 02-24-2009, 04:33 PM   #7 (permalink)
good to know!
let us know if all is well
Old 02-24-2009, 05:01 PM   #8 (permalink)
apalmer1's Avatar
the splines are just binding up, push it in as far as you can then thread the nuts on the back of the backing plate studs and tighten them a little at a time to pull it in straight. tell your buddy that he might have a bent axle housing if its getting stuck that bad, but if he hasn't noticed weird tire wear or vibration on that side its probably fine, my taco axles get stuck like that every once in a while.
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress.
85 pickup, 327sbc, truggy, in progress.
86 mazda b2000 street queen haha.
92 mazda B2600i 4x4 absolutely mobs.
81 ford bronco drinks gas
90 mazda mx-5 all original.
when in doubt, tach it out.
apalmer1 is offline
Old 02-24-2009, 05:04 PM   #9 (permalink)
SwampThing's Avatar
It's usually nice to have a friend fiddle with the flange while you're stabbing the shafts. Shouldn't be too hard, might want to check out the bearings and see if the shaft is bent.
__________________
Toyota 00 PU: Killed in Action - Pending
Toyota 84 PU: Killed in Action ? Beach Rollover. In Surgery: LT1 Swap, New Cab, Marlin Dual Ultimate, D60s.
Toyota 89 4R: Killed in Action - Dukes of Hazard'ed / Evil Knievel'ed
Toyota 95 PU: Killed in Action - Retread blow-out roll over
Clintimus Maxiumus
Quote:
Originally Posted by thook View Post
One day a child will ask,"Mommy, why are there endangered species?". "Well, dear, one day someone invented the truck... Then, Clint was born!"
SwampThing is offline
Old 02-24-2009, 05:07 PM   #10 (permalink)
abecedarian's Avatar
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
....carrier bearings could cause the shaft to misalign and not seat...
__________________
Quote:
Originally Posted by Junkers88 View Post
I went and looked at that Ford.... I can't tell if the vehicle was just abused or if domestic builders don't see the point in building something that will last and look good.
I'm going outside to hug my 4runner.
Quote:
Originally Posted by DeathCougar View Post
Abe so far has been spot on, 100% correct. As usual
Insomnia: it's a way of life.
abecedarian is offline
Old 02-24-2009, 10:48 PM   #11 (permalink)
Alex 400's Avatar
after tightening it up, does it turn?
__________________
1994 toyota 4Runner SR5 Limited 4wd, 3.0 V-6, 5-speed, 31/10.50-15 Toyo A/T, All Pro 1.5" coil springs, Bilstein front shocks, doetsch tech mv12's rears, MC heavy duty clutch, 2.25" Cat-back with 50 series Flowmaster 169,xxx miles
Quote:
Originally Posted by slisdexia View Post
I blame the automatic transmission for the wussification of America
Quote:
Originally Posted by toyminator2000 View Post
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE
Alex 400 is offline
Old 02-25-2009, 01:10 AM   #12 (permalink)
space-junk's Avatar
Quote:
i love it when my lady friend fiddles with the flange while i stab it with my shaft...
sorry swampy... couldnt resist...
__________________
Trailer Re-Build - Check it out!!!
From the back of the crowd you hear a slightly slurred Clint..."Hell that ain't nothin'. Give me the damn keys and hold my beer, I'll show you how to kill a Yota."
1990 4RUNNER
V6 & 5spd. | Custom Cat-Back | Magnaflow Muffler | ProComp Light bar | OME 901HD springs | Cobra 19 Ultra III
Pro comp Driving Lights | 33x10.50 BFG A/Ts | 4.88 Factory Gears | Hi-Lift Jack
space-junk is offline
Old 02-25-2009, 08:50 AM   #13 (permalink)
ZUK
ZUK's Avatar
I've had that happen to me before....it's just the bearing catching on the outer housing lip. Put the 4 backing plate nuts on and tighten them evenly and it will POP into place.
__________________
www.gearinstalls.com
2001 white Xtra-cab Taco 3.4L auto TRD
88 Runner/V6/auto/31"/5.29gears
ZUK was what my friends in 1990 "tagged' me with when I was building a brand new white 1990 Sami for a magazine cover. The name stuck and I haven't been able to shake it off....not even with antibiotics.
ZUK is offline
Old 02-25-2009, 05:46 PM   #14 (permalink)
wow Troy... family safe man, family safe
Old 02-25-2009, 05:55 PM   #15 (permalink)
muddpigg's Avatar
Quote:
LOL, thats how we got a family. Wrenching women are hhottt.
__________________
http://www.youtube.com/watch?v=rqtr_RvR3sY
Balljoints for sale. Open to trades and offers. http://www.yotatech.com/f11/ball-joi.../#post51278784
muddpigg is offline
Old 02-25-2009, 05:58 PM   #16 (permalink)
Quote:
well I'm not denying that
I dunno though, some can be a little manly
Old 02-25-2009, 05:59 PM   #17 (permalink)
muddpigg's Avatar
IAM how's exhuast doing?
__________________
muddpigg is offline
Old 02-25-2009, 06:01 PM   #18 (permalink)
well, it sounds good, accept for a leak in that emessions tube that runs back behind the motor, lol
I'm not screw'n with it; all the emissions crap is going away on with the new motor I hope to start puting together very soon
Old 02-25-2009, 06:05 PM   #19 (permalink)
muddpigg's Avatar
That back plate is a PITA to get to.
__________________
muddpigg is offline
Old 02-25-2009, 06:26 PM   #21 (permalink)
shaft wont go in
WOW, I think I will pay someone else to instal my locker. Sounds alot less expensive than ending up with a family from it.lol MuddPigg best of luck to you buddy. Stay safe.
dewiseman is offline
Old 07-04-2009, 12:35 PM   #22 (permalink)
Stuwy123's Avatar
Rise Dead Thread RISE!!!
I've pulled a couple diffs from the wreckers but I've always had a problem with the brake lines. I usally just beat them around enough to get the axel outta the diff.
I've never dealt with brake lines before and now it's time to install some diff into my truck.
Do you have to bleed the brakes after you pull the lines off? I've never done that before. I'm hoping for an easy way around that. I've heard you can just wrap the ends with a plastic bag to keep it from collecting too much air.
Does this work?
Stuwy123 is offline
Old 07-04-2009, 12:42 PM   #23 (permalink)
mojo4x420's Avatar
Bleed them. It takes 10 minutes and brakes are important. New brake fluid is always good.
The bag trick kinda works, but I always find it leaks and unless you are really quick, you'll end up dripping fluid everywhere and possibly running your master dry. If your master runs out, you should really remove it and bench bleed it. Shaved golf tee's in the brake lines work better. But bleed anyways.
__________________
Tags
1986, 1990, 4runner, 4x4, axle, b2000, b2600i, filling, install, mazda, pumpkin, rear, spline, starter, tool, toyota, utube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear seat is stuck down! jodynich General Vehicle Related Topics (Non Year Related) 3 12-29-2006 03:41 PM
Rear Axle leak at Pumpkin! dbikeman 95.5-2004 Tacomas & 96-2002 4Runners 1 12-18-2006 03:22 PM
Gas Tank Install...Stuck at Full Level! ravencr 95.5-2004 Tacomas & 96-2002 4Runners 0 01-18-2004 03:28 PM
Rear seat stuck jsteele 95.5-2004 Tacomas & 96-2002 4Runners 4 02-06-2003 12:27 PM
2009 InternetBrands, Inc.
