Rear Pinion Seal Replacement
Mine is definitely going out. I looked under it today after i got back from wheeling.
There was a fairly large puddle of oil, and the bottom of the diff is covered in oil.
And another headache, after getting the oil changed in the engine, i noticed a drop from underneath it now. I'm hoping it's rear half-moon and not my rear-main.
Anyways, is the rear pinion seal hard to change?
Searched, no threads about it.
Found the 4crawler one though.
Doesn't matter, my breather thingy was clogged with mud and gunk.
And my valve cover wasn't as tight as it could have been, so i'm leak free as of today.
yep, i looked through my FSM.
It's pretty simple, but like i said, i drove her around for 30 mins with an unclogged breather and no more leaky.
try this link http://www.4crawler.com/4x4/CheapTri...eal/index.html
I'm surprised you were leaking out of the pinion seal and not your axle seals (at the wheels) .. Which usually is where the pressure escapes (clogged breather).
Might check your drums.
Truly?
I searched the words "Rear Pinion Seal Replacement" and found 18 threads. 2 with the EXACT same title as yours, and 1 almost(Pinion Seal Replacement).
https://www.yotatech.com/search.php?searchid=6583520
Busted!!!!!!!!!!
Busted!!!!!!!!!!
Let's try that again....here https://www.yotatech.com/search.php?searchid=6583520
Or are you just pulling my leg?
WAIT!!! HOLD THE TRAIN!!!
I think I know what's really going on with that.
I tried clicking the link while I was "logged out", got the message you got(no matches).
Try logging in, then clicking that link, or repeating the search.
Sorry, I hadn't ever noticed that, news to me too.
yeah but i am logged in, lol.
hence the reason i'm able to write messages xD
Doesn't matter, all those threads i saw before.
The two with the exact same name aren't a writeup. The one that the oil is pouring out of isnt a writeup either, but it did tell me about the diff breather.
Like i said, i found 4crawlers guide so it's all good.
Gotcha, I'll let it go....the 4crawler link is the best anyways.
But, wtf is with the search not working sometimes? LAME!
Here's them other threads for those not finding them.
https://www.yotatech.com/forums/f16/...acement-61671/
https://www.yotatech.com/forums/f2/r...acement-63014/
https://www.yotatech.com/forums/f120...cement-187382/
voiddweller
19
05-02-2016 09:10 PM
jennygirl
11-17-2015 11:24 AM
cchinny
06-25-2015 08:11 PM
