rear pinion bearing
Old 05-28-2008, 06:24 AM
94_yota_pickup's Avatar
rear pinion bearing
I just recently bought a 94 yota pickup and it is leaking oil pretty bad from the rear pinion seal and you can also move the driveshaft bad so i am presuming it is the rear pinion bearing anybody know how hard it is to change this?
Old 05-28-2008, 06:26 AM
SwampThing's Avatar
Might as well change gears now if you were ever gonna do it before. You'll be right there
Old 05-28-2008, 10:21 AM
904_runner's Avatar
Mine is leaking, and i was contemplating regearing while i do it. (i mean while a shop does it) But isn't it somewhere around $1000 bucks for gears and the installation costs?
Old 05-28-2008, 01:33 PM
SwampThing's Avatar
You can expect to pay ~$130 for gears, $100 for install kit, and $100-150 to have the gears installed. And thats for one diff. X2 if you have 4wd, because its best to do both at the same time, so $600 on the low side, $800 on the high side.
Old 05-28-2008, 02:10 PM
TORTIS's Avatar
if you can't find anybody to do the work i highly recommend Zuk. he is half way across the country from ya, but he does great work at a fair price. are you going to put a locker in while you have the diff out?
glowz825
01-25-2022 09:28 AM
bigjstang
08-25-2021 12:41 AM
the1998sr5
15
07-14-2020 08:35 PM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
Quick Reply: rear pinion bearing
