rear main seal lekaing
Old 03-18-2013, 02:28 PM
wolf28's Avatar
well my rear main seal is leaking on my 3.0L it drips maybe 1 drip a day and iv been running 10w30 with a bottle of lucas and it seems to slow the drips. i was gonna change out the seal this winter but im becoming over whelmed with it
is there any kinda oil or additive that will help the seal out or maybe switch to a 15w40 oil any input would help
Old 03-18-2013, 02:33 PM
bob200587's Avatar
If the seal is shot for sure, you might as well try one of those rear main seal repair liquids at the auto parts store.
Old 03-18-2013, 02:35 PM
wolf28's Avatar
never seen them or heard of them
Old 03-18-2013, 03:43 PM
Co_94_PU's Avatar
Probably a stop-leak product. http://www.google.com/search?q=stop-leak+oil+seal
Personal preference of course but i'd rather dump a fresh quart routinely than run any kind of sealer.
Old 03-18-2013, 05:16 PM
AZ94RUNNER's Avatar
From experience try not to use some magical fluid to fix a leak. its a tough job but your engine will that you for doing it. Cheaper than figuring out that magical fluid clogged up other things also. Like your oil pick up in your oil pan.
Old 03-18-2013, 05:27 PM
wolf28's Avatar
i was thinking about switching over to a 15w40 oil something thicker to help slow or stop it
Old 03-18-2013, 05:29 PM
AZ94RUNNER's Avatar
**your engine will thank you for it.
Old 03-18-2013, 05:33 PM
wolf28's Avatar
im just tired of working on it and is 1-2 drips a day worth it
Old 03-19-2013, 06:40 AM
oldblue's Avatar
let the rough end drag man. your truck burns more oil than that a day. check your oil level at every gas fill up, and don't worry about it. when its time for a clutch, then do the seal.
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
Iceman4193
07-15-2015 04:48 PM
Kalihi,HI
07-09-2015 04:29 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: rear main seal lekaing
