| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Rear Lockrite Broke...now what?
#2 (permalink) |
I have 7k on mine, no problems, and it was used with 12k on it before that.
Are you a heavy foot kind of a guy? I drive mine pretty light. The thing that goes bad on them are the pins between the center section and the outer plates. Pretty easy to fix, from what I have read. The Detroit will be a far more stout locker, as it replaces the stock cast carrier with a machined carrier. Not sure on the ratcheting mechanism being any more aggressive or reliable, others may have an opinion.
__________________
1989 4Runner V6 Auto IFS, 1.5" BJ spacers, 2" OME leaf springs, OME T-bars, 3/4" 4Crawler body lift, 1" 4Crawler front diff drop, ARB Bull Bar, Warn M8000, PIAA driving lights, MC rear bumper, OME shocks f/r, OME steering stabilizer, Total Chaos idler arm, 33x10.5.x15 BFG AT's on RockCrawler 15x8"x4.5"BS wheels, Downey Headers, Flowmaster 70 series, 5.29 gears, LockRights f/r Build Thread: http://www.yotatech.com/f191/outlawm...thread-187558/ |
#3 (permalink) |
Just repair the one you have for the cheapest option.
Elockers can be had for 400 bucks. Cheaper than detroit. Detroit is a significant strength upgrade and will be far stouter than your lockright. From what I've seen, the detroits also unlock and lock much more smoothly than the lockrights.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction|Now on 35's -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy -Most Recent Morph |
#4 (permalink) |
you should probably take the 3rd out and assess the issue before spending more money on a different locker. like said, it's probably related to the springs that keep both sides apart, which would be a very cheap fix. there's not much else to to the lockrite that i can see self destructing. i wouldn't even bother taking it to a shop, a lockrite install is like 3/10 banana job.
a detroit is a better autolocker than the lockrite, but the install is more involved since you'll be replacing your carrier housing which may require different clearances to make your ring/pinion contact pattern happy. elocker would be my next choice. i don't mind my lockrite, but i'd much rather have the option to be open on the roads.
__________________
1993 X-Cab - 4wd - 5spd - 22re - 200k miles | 31" ATs | 4.88s | LockRight (R) | diff breathers | IFS Truss | OME suspension | BJ spacers | no swaybar | Cobra 76xtr CB | 2002 UZJ100 Land Cruiser | 285 GY DuraTracs | 2001 Corolla S 2001 SV650 naked |
#5 (permalink) |
Just replace the broken spring and/or pin(s)...
Ive had my lockright in for about 20,000km. I beat on it very hard everyday, no problems!
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 255k |2.25" catback w/ magnaflow cat + no muffler | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's and 700ffs |4" reverse lights| Grant GT |idler arm brace| E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#6 (permalink) | ||
repair it.
__________________
1990 Toyota 4Runner 22RE 5spd *Aussie Locker*York OBA* Quote:
Quote:
More info on 4Runners |
#7 (permalink) |
No issues with mine. Driven across country, wheeled it, DD, vacation.... Take my lockrite everywhere no issues. When you assess the damage and replace springs measure the clearances. Not all professionals are as professional as others.
__________________
http://www.youtube.com/watch?v=rqtr_RvR3sY Balljoints, 26mm torsion bars, idle arm for sale. Open to trades and offers. http://www.yotatech.com/f11/ball-joi.../#post51268965 Non ADD locked 4:88 front axle. http://www.nw-wheelers.com/forum/showthread.php?t=47994 |
#8 (permalink) |
Here's a link to a rebuild kit http://www.summitracing.com/parts/PWT-1025350KAP/
__________________
1986 pickup 4x4 SR5, 5-spd, 33x10.5 BFG KM1 muds, 2" body lift, front and rear lockrights, 4.88s, 4.7 t-case with Dave'z twin stick, BudBuilt crossmember with 1" drivetrain lift, Downey grille guard and skid plate, TG sliders Still needed: rear bumper (Marlin, TG, or Dave'z) |
#9 (permalink) |
Aussie!
__________________
-1990 2 door 4runner, 22re, off brand muffler, 31x10.5 BFG AllTerrains, 15x8" Cragar D windows, Smittybilt front bumper, Badland Rear bumper, husky liner floor mats, Uniden 520 cb radio, 9 foot fiberglass whip, Manual hub swap. Coming Soon: -1.5" bj spacers, 2" coil spacers(need to install) |
#10 (permalink) |
I won't ever run another auto locker in the rear unless it is a full detroit.
My lockright broke and took out my ring gear that zuk set up. ![]() Pull the diff ASAP and inspect it
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, front high pinion W/ARB, 30 spline longfields with chromo hub gears, 5.29's, 39.5" iroks on Beadlocks, Armor'd Duals coming soon: Pending funds My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#11 (permalink) |
Mine have done me for almost 2 years now, I have stuffed up my uni joints and a transfer case, because I am a lead foot who is stomping on a V8 as well. I am f*****g hard on my car most of the time and they haven't let me down yet.
#12 (permalink) |
i'll take it! no, seriously. if ur gonna ditch it for a detroit let me know
#13 (permalink) |
Interesting, I've never heard of an Aussie failing, only Lock rites.. how about the Powertrax softlocker? any one got experience with those?
I have an Aussie in my rear axle, only 1k on it tho. I like it a lot =) LOVE squeeling out at gas stations, HAHA
__________________
1987 Pickup, single cab, 22R, new head, 260 cam TG 3" SAS, rear disc brakes, chromoly rear axles, Chromoly Birfs, Tcase brake, 37x12.50R15 MT/Rs, 5.29 gears, rear Aussie Locker, front Detroit Truetrac. |
#14 (permalink) |
If you bought it from PORC they will garrauntee it reguardless of tire size. Locrite has a tire size limit.
__________________
#15 (permalink) |
#16 (permalink) | |
X3 on that. I've had Detroits since '94 and wouldn't ever consider anything less. Would like an ARB for up front though.
__________________
'85 4Runner totaled and brought back 22RE-C 5spd 4.88's, Rear IFS axle with Detroit Locker and Tru Trac up front Doug Thorley Header and LC Engineering Cam, K+N, Downey 3 inch leaves and Rubicon shackles with Pro Comp shocks 32x11.5-15 BFG AT's Quote:
| Tags |
| broken, fix, forum, front, lock, lockers, lockrite, lockritecom, lockrites, pinion, powertrax, rear, rite, sale, toyota |
