rear end noise???
Old 10-22-2007, 08:56 AM
run4her's Avatar
Exclamation rear end noise???
I have a 90 4runner, i just put my lift on and now when i am costing the rear end makes a vibrating noise.
Old 10-22-2007, 09:01 AM
Ringmaster's Avatar
Pinion angle is too much after lift.
How high of a lift did you add?
Old 10-22-2007, 09:13 AM
run4her's Avatar
7 " but how can u change pinion angle with coils?
Old 10-22-2007, 09:28 AM
traben27's Avatar
You'll need a new (longer) driveshaft...That will fix the angle
Old 10-22-2007, 09:33 AM
run4her's Avatar
huh, i have heard of just having a joint added to? does that sound right?
Old 10-22-2007, 09:35 AM
traben27's Avatar
Hmm...I'm not sure. I've never heard of that. Are you thinking of a spacer maybe?\
Edit: Try Here
or Here
Old 10-22-2007, 09:39 AM
run4her's Avatar
i dont know what the guy was talking about. it would probably help to greas the shaft to huh? Are there longer coild than l\c coils avalable because i have l/c coils and spacer right now.
Old 10-22-2007, 09:44 AM
traben27's Avatar
OME 860s I believe. MarcP (i dont know if he's on here anymore) switched his LC's out for those and it gave him more lift and a stiffer ride.
Old 10-22-2007, 09:53 AM
run4her's Avatar
Well i looked at them and they dont give me enough lift. The rear fender well to wheel lip is 20" they give 17"
Daneums
08-20-2015 05:36 AM
razorman8669
07-12-2015 12:13 PM
hangtown88toy
07-10-2015 02:33 PM
akaphilly
07-09-2015 02:18 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: rear end noise???
