Rear end help.........
Ok, I am removing my rear end chunk in anticipation of my "new" rear end....
On the top of the chunk there is a cable that is attached to the top of the housing......
How do I get this off???? I removed the bolt that was screwed thru it, but it still won't come off.....
What is this for?
Thanks for the help.......
Chad
What is this for?
Chad
Yep, a flat screwdriver and a bit of patience should get it out in one piece. The sensor-to-housing interface is sealed by an o-ring, which is mounted on the body of the sensor itself, and will come out when you remove the sensor.
the1998sr5
15
07-14-2020 08:35 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
