Rear drum help
Rear drum help
Alright so I just bought a 87 4wd and it has some issues with the passenger rear drum. I kept hearing some metal on metal squealing and what sounded like a popping and clunking type sound ( like throwing a wrench into a piece of machinery) best way I can describe it. Well my first thought was rear end but couldn't get any noise out of the rearend and when I grabbed the lug nuts on the pass wheel to check wheel bearing they were on fire hot I could feel the heat radiating from the drum. I've backed the star wheel all the way off and the brakes are still very tight. The driver side rear will make a full revolution Spin with a little push from one hand. The parking brake will pull 26 clicks before it stops. My main question here is where should I start looking?? I'm a complete novice to drum brakes. Thanks for any advice. Also the pedal goes almost all the way to the floor. Mc maybe? Could a bad mc cause just one rear tire to stay engaged like that?
Bell crank isn't seized. They did have a gap between them and backing plate I adjusted so that they don't and that didn't help. Drums are coming off tomorrow hopefully. Brake job, wheel bearings, seals while I'm at it.
Well got the drums off and the pads are pretty much non existant. Still not sure why the pass side was so hot the drum came off with almost no effort with two jacking bolts in the drum. The driver side slide right off but it looks like someone took a case of grease and packed it all in the drum?? The wheel bearings are shot so axles are coming out as well today. My differential has a lot of slop on the input shaft so perhaps it'll come out as well and I'll just have a new rearend by the time it's all over
Athansinis
07-27-2015 08:38 AM
CanRunner
07-20-2015 01:29 PM
icentropy
07-14-2015 10:23 AM
