rear drum to disk brake conversion kit
Old 06-09-2016, 03:44 AM
canuckhunter's Avatar
I'm rebuilding a 1992 Toyota Pickup extra cab 4x4 V6. I'm looking to convert the rear drums to disk. I do not see an emergency brake with the kit. Has anyone done this conversion? If so, does the emergency brake work?
Old 06-09-2016, 07:35 AM
arlindsay1992's Avatar
What kit are you talking about? There are a dozen companies making disk brake conversions. If the caliper you use doesn't have a parking brake, then you won't have a parking brake. Many kits have no provision for a parking brake so you'll need to use a transfer case brake.
Old 06-09-2016, 08:48 AM
osv
osv's Avatar
people have been asking for rear disc brakes with e-brake capability for the last couple of decades, at least.
speculation on pirate was that insurance concerns were preventing it from happening, but that seems to be a bit of a stretch.
Old 06-09-2016, 12:53 PM
wyoming9's Avatar
I think the hard part would be making cables that would work.
Transfer case brakes might not be legal in some states
Old 06-09-2016, 02:48 PM
wallytoo's Avatar
what concerns? there are numerous oem rear disc brake vehicles with a parking brake incorporated.
Old 06-09-2016, 05:01 PM
osv
osv's Avatar
unless something has changed in the last couple of years, none of 'em have a toyota-compatible parking brake cable hookup.
if anyone has any ideas on how to do it, post 'em up.
Old 06-10-2016, 10:53 AM
wyoming9's Avatar
don`t some of the newer 4Runners Have rear disc brakes ??
It would be no big deal to weld on spring pads .
95 % factory Toyota Parts
It would not be to hard to interface with the stock E-Brake cable at the intermediate lever.
I like my Drum brakes I have no problems so never did more then thing about how to do this
Being able to Fabricate one looks at things different.
Old 11-25-2016, 06:40 PM
LouDawg's Avatar
completed 1984 Toyota rear disk/disc conversion with parking brake
I just completed the rear disc conversion on a 1984 chassis. Thanks to this site with the write ups and photos especially, it was relatively easy. The kit I bought from 4 Wheel Drive Manufacturing and was made by Sky Mfg. I ordered everything from 4WD Mfg - kit, rotors and calipers with the e-brake provision - knowing some alterations and manufacturing of brackets and such would be needed. No use repeating what is already on the site about brake conversion, but here are pictures of what I did for e-brake adaption. The top bracket goes between the bump stop and the top of the springs - notice the hole for the spring centering bolt. The lower bracket pivots on the bolt on the upper bracket. It allows the stock parking brake cable to pull 90 degrees around the spring bump stop.
Here is a view of the two parts mounted.
Now need linkage between bracket and e-brake hardware on calipers
Top view of same
Old 11-25-2016, 06:53 PM
LouDawg's Avatar
The e-brake linkage 1/4 inch ready rod/all-thread and a 1/4 inch linkage for like carburetor. If it breaks will go to 5/16 inch.
Here is another view but is missing the 1/4 inch locknut for slack adjustment.
Old 11-25-2016, 06:54 PM
LouDawg's Avatar
Old 11-25-2016, 07:17 PM
osv
osv's Avatar
that's pretty cool lou! thx for posting it.
Old 11-26-2016, 09:32 AM
ewong's Avatar
FYI
This is the "expensive" way to do it.
Full Floater rear axle in the process.
It uses the latest 4Runner rear disc brake with the drum parking brake.
Note that the price listed on the page is the UPGRADE cost.
You still have the ADDITIONAL cost of the Full Floater Kit
To say nothing of the parts you will need (IFS hubs, SFA stub, Brake Parts etc)
http://frontrangeoffroadfab.com/drot...e-upgrade-kit/
89hilux1
02-29-2016 02:23 PM
SueLu
02-24-2016 08:23 PM
alva22re
02-20-2016 04:21 PM
MudWaspSR5
02-09-2016 11:28 AM
goofybud16
02-06-2016 01:29 PM
Quick Reply: rear drum to disk brake conversion kit
