Rear Disc Swap
Old 08-29-2014, 01:45 PM
  #121
viaduct09's Avatar
Originally Posted by eric08021
Well that's cool if u have means to hook up rotors yourself. I stuck with a kit that comes with all I need. And I can use 1985 toyota pickup rotors and calibers. Where I can get the parts from NAPPA or pepboys. The only down side the rotors have to be pressed on the axles...
No pressing the rotors on the axle for my brackets! You are likely going to have to grind a few thousandths off the axle on the wheel stud side...to slide the rotor over!
Plus any parts store that carries Toyota rotors and calipers will do! Nothing special about this conversion...Your choice either Pre-1985 or use IFS brake components!
Here's a link from a Yotatech member that did the conversion using IFS calipers and Tacoma front rotors!
https://www.yotatech.com/forums/f116...nstall-191482/
Anyone want any brackets private message me!! $75 bucks shipped! (2 brackets) FREE Shipping Lower 48 and Canada!
Old 03-22-2015, 11:43 AM
  #122
NorthBayPete's Avatar
Check out my swap at the bottom of this page.
https://www.yotatech.com/forums/f88/...mounts-281589/
Old 05-16-2015, 08:08 AM
  #123
stanz's Avatar
Curious if anyone has tried rear RX-7 calipers. They use a side pull parking brake cable.
Old 06-27-2015, 06:21 PM
  #124
TheeMikeB's Avatar
Resurrection, been searching through all these threads and can't find what I'm looking for...
I have a new to me rig that has the rear discs done on it, and i'm going through the truck and noticed that the rear disc brake pads are a bit larger or off canter from the braking surface of the rotor... meaning the brake pads extend over the edge of the brake rotor and not exactly evenly... these appear to be the gm style calipers but not sure which rotors are on the rig.... is this normal?
Old 06-27-2015, 06:37 PM
  #125
viaduct09's Avatar
Do you have a pic to show the setup?
Old 06-27-2015, 07:02 PM
  #126
TheeMikeB's Avatar
Actually looking at the pics in this thread closer.... Mine look just like this so I guess it's normal.
You can see the pad on the front side of the rotor is hanging off about 1/4 of the way and the pad on the rear is slightly off too. Strange but I guess this is what you get when you do this kind of swap.
edit...
here is an actual pic.. a bit difficult to see since the wheel is on the truck in this photo.. but if you look carefully you can see that the pads stick out over the edges of the rotor, they don't line up perfectly along the arc of the rotor. My question is that normal?
Old 07-02-2015, 02:24 PM
  #127
viaduct09's Avatar
Monster Chevy calipers with smallish Toyota rotors your gonna come up short! Rear brakes only do 20% of the braking!
Old 07-03-2015, 01:10 PM
  #128
TheeMikeB's Avatar
Yeah I get that, but I have read that others use larger rotors from a Chevy truck too, so trying figure out if the pads hanging past the rotors is normal or would it be fixed with the correct rotor?
Old 07-03-2015, 01:35 PM
  #129
Yota.Jay's Avatar
Rear Disc Swap
I kind of want to do the transformation.
Old 07-03-2015, 02:21 PM
  #130
viaduct09's Avatar
Yes, bigger rotors would fix that! With the 2nd pic you got 1-1.5 inchs to get your tire/rim over the caliper! You only got so much room!
That's why the brackets I sell use Toyota truck IFS calipers & rotors! You can use early or newer Toyota truck parts.
Old 07-03-2015, 04:09 PM
  #131
TheeMikeB's Avatar
Duh... I didn't even think about the caliper clearance, and I still have 15" wheels so guess i'll be keeping this setup.
Like I said this truck is new to me and just going through it to make sure everything is solid. Appreciate your help.
Old 07-05-2015, 08:30 PM
  #132
TheeMikeB's Avatar
Something else I noticed on this writeup...
Those Cadillac calipers have the banjo fitting on the topside of the caliper, the others seem to have them on the bottom side. The ones on my rig have them on the bottom and I think they hang to low and are in danger of rock bashing.
Going to be swapping out for the Cadillac ones and rerouting my brake line on top of the axle out of the way!
Old 07-25-2017, 01:51 AM
  #133
TurboDieselRunner's Avatar
Subscribed
Old 01-24-2018, 02:49 PM
  #134
YotaRick27's Avatar
Great pics thanks
Old 12-05-2018, 07:36 PM
  #135
akamon808's Avatar
Disc brake swap
hi, doing a rear disc brake swap on my 88 4runner. What did you use for a e-brake? Thanks Aaron.
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
icentropy
07-09-2015 02:12 PM
87turboPA
07-09-2015 05:58 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Rear Disc Swap
