Rear Defogger NFG
Old 01-29-2008, 03:39 PM
mike92runnerSR5's Avatar
Rear Defogger NFG
My 2nd gen rear defogger hasn't worked for a while. Fuses all seem okay. Anyone know of a quick fix? The dash switch lights but thats it. Any suggestions would be appreciated.
Old 01-29-2008, 08:29 PM
eric-the-red's Avatar
On my 93 the wires came detached from the bottom of the defogger grid. You have to remove the panel on the tailgate to see it though. The 2 wires go onto a small metal bit that's attached to the bottom of the window, or not attached in my case. I managed to fix mine by soldering the metal bit back on.
Old 01-29-2008, 08:39 PM
AZTOAK's Avatar
x2, One of my wires broke off the bottom of the window. The only way to fix it was to solder the wire back onto the broken connection that was left on the glass.
Old 02-02-2008, 02:20 PM
thanks guys, I'll check it out..I thought it might be the defogger relay..so I think I'll check that also..has anyone ever replaced their defogger relay?
Old 02-02-2008, 02:58 PM
GO GIANTS...bump
Old 02-02-2008, 03:13 PM
sleaz22xx's Avatar
nah GO PATS!! (sorry had to)
Old 02-03-2008, 08:10 AM
leebee's Avatar
youll want to make sure that the wires do not get tangled up when the glass goes up & down or it will break the solder joint. ive tried several times to limit the wire movement without much success.
lee
Old 02-09-2008, 03:47 PM
I plan on pulling the rear hatch cover tomorrow and taking a look at the wires...I had the window motor replaced previously...still gotta love them GIANTS..
okamikai
04-30-2018 10:19 PM
kirkrunner
07-27-2015 07:59 PM
SMOD
07-27-2015 01:45 PM
Athansinis
07-27-2015 08:38 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Rear Defogger NFG
