Rear bumpstop removal
Old 06-01-2008, 06:45 PM
Crawdad's Avatar
How do the rear bumpstops come off? Do they unscrew, or are they bolted on?
Old 06-01-2008, 07:12 PM
just a 22re's Avatar
well on what car/truck? you have three there im guessung the yota well i dont know but someone is going to ask unless they have one like yours
Old 06-01-2008, 08:13 PM
Crawdad's Avatar
The Yota. If the Ramcharger hits the bumpstops the springpacks probably broke
Old 06-01-2008, 09:27 PM
norcalsvx's Avatar
do they look like this? you can always hack some off
Old 06-01-2008, 09:55 PM
Matt16's Avatar
On a coil-sprung 4Runner, they prevent the spring collapsing enough to let the shock fully collapse. Bumpstops save shocks. I think they are glued on. Really. Mine fell off.
With aftermarket springs, you may not need them.
Old 06-01-2008, 09:59 PM
Crawdad's Avatar
Ha, not good. I need to take them off to get the springs off a little more easily. Hell, they very well may be glued on. Matt, did you replace them after they fell off? Any problems?
Old 06-02-2008, 12:26 AM
Matt16's Avatar
I never did, I have had no problems. I'd need to treat the rust then epoxy the bumpstops back on.
Old 06-02-2008, 05:32 PM
Crawdad's Avatar
For anyone searching, the rear bump stops on a coilsprung 4runner can be removed by sticking a 12mm deep well socket into the hole on the bottom, and taking out one bolt. Easy. Definitely use a deep well socket, or you will end up losing your socket inside the bumpstop, it's a tight fit.
This makes installation of lift springs, or coil spacers MUCH easier.
I just left mine off, if I end up bottoming out and ruining shocks, I'll set up a bumpstop system on the frame or axle.
Iceman4193
07-15-2015 04:48 PM
icentropy
07-14-2015 10:23 AM
hangtown88toy
07-10-2015 02:33 PM
icentropy
07-09-2015 02:12 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Rear bumpstop removal
