Rear Braking Problem & LSPV - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-10-2006, 09:52 AM   #1 (permalink)
I had to change the lines going from the front to the LSPV (load sensing proportioning valve). Unfortunately I did not keep track of which line goes where. I searched the forum, but could not find the answer or any other place online. I also have a Haynes book, but it does not give a diagram (what did I buy the book for?) Which line coming into the lspv comes directly from the master cylinder? Is it the top line or the bottom?
The symptom that makes me think that I might have a problem here is that after replacing the lines and the master cylinder I don't have very good brakes. Sometimes I have to pump the brakes in order to get enough braking power. I have bled the system multiple times and have no air coming out anywhere.
Also, I don't seem to have any rear brakes. I know this because when stopping on gravel the fronts would lock up, but the rears wouldn't seem to be doing anything. I adjusted up the one drum, but was unable to get the drum off on the other side. I don't know if this could be the problem. I do get pressure on both back bleeders when I bleed the lines which I have been told should indicate that they are adjusted ok (or at least enough to give pressure). I have not adjusted the lspv, which I may still do. The fact that when I bleed the rear and I get fluid indicates that it must be allowing fluid by, but I may be wrong here.
Any help would be appreciated. Thanks.
bereanmh is offline
Old 08-10-2006, 10:10 AM   #2 (permalink)
eric-the-red's Avatar
Did you bleed the LSPV, it needs to be done last. Apart from that I can't help much, I tried not to touch that valve when I had my 2nd gen.
eric-the-red is offline
Old 08-10-2006, 03:00 PM   #3 (permalink)
Yes I have bled it. I have done it last too. In trying to figure this out I have bled it in all different orders.
Some info I didn't give. My truck is a 4wd 92 w/ a 4 cylinder engine and 5 speed.
bereanmh is offline
Old 08-10-2006, 03:11 PM   #4 (permalink)
Try this link, it might help. Like I said before I don't know much about the LSPV
http://www.off-road.com/toyota/cheaptricks/brakevalve/
Old 08-10-2006, 08:32 PM   #5 (permalink)
LOCKnGO's Avatar
I'm glad you posted this, I was thinking of removing the LSPV all together, and installing a manuel PV. This is a lot cheaper.
__________________
"If it's simple,
then it's wrong! "
Les Claypool
LOCKnGO is offline
Old 08-11-2006, 10:19 AM   #6 (permalink)
Look which line goes where
Quote:
When you take yours off to replace it, can you look to see what line goes where in the old proportioning valve. Thanks.
bereanmh is offline
Old 08-11-2006, 08:00 PM   #7 (permalink)
LOCKnGO's Avatar
Quote:
Well I was going to try doing what eric-the-red posted in that link. I mean if I already have a valve that can be manualy (err jerry-justed) adjusted I am going to try that first. I never did like Toyotas idea of the pully/ cable/ hydralic Pvalve system.
__________________
"If it's simple,
then it's wrong! "
Les Claypool
LOCKnGO is offline
Tags
4runner, 71, 93, bleeder, buy, chevy, diag, diagram, inside, lspv, olds, online, problems, proportioning, speed, toyota, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
NEW: 4" drop Panhard & LSPV brackets! CHEAP! 4Crawler brand! Simann The Classifieds GraveYard 29 03-12-2007 04:01 PM
Braking Problem CJM General Vehicle Related Topics (Non Year Related) 10 11-11-2006 10:31 AM
Braking problem!? 94toyota4x4 86-95 Trucks & 4Runners 8 09-19-2006 06:26 PM
Braking problem. Haniblectre 95.5-2004 Tacomas & 96-2002 4Runners 18 10-16-2005 03:28 PM
braking problem 98limitednewbie 95.5-2004 Tacomas & 96-2002 4Runners 7 05-19-2003 10:28 AM
2009 InternetBrands, Inc.
