Rear brake shoe replacement.
Old 01-24-2008, 01:55 PM
kmat123's Avatar
My drivers side inner rear axle seal was leaking and soaked my brake shoes with gear oil. I replaced the inner/outter seals and wheel bearing and was wondering if I have to replace the brake shoes on both rear wheels or if I could do just the drivers side that was contaminated. My passenger side shoes have plenty of life left. Thank for you help!
Old 01-24-2008, 03:30 PM
GSGALLANT's Avatar
You should always replace, shoes, drums, pads, or rotors in pairs. If you replace one side, replace the other to maintain even braking.
breknraj's Avatar
While you probably could, I wouldn't. I believe in trying to keep both side as equal as possible. It would probably be a good idea to have a look at the seals on the other side, too. If one side was gone, then the other probably isn't far behind.
The other part is that I have never seen a single set of shoes for sale at any reputable location.
Old 01-24-2008, 04:08 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Yep....they always come in a set brand new. No other way. And besides, you'll need a core. You do where I go, anyway.
Old 01-25-2008, 05:27 PM
leebee's Avatar
x2, no scrimping when it comes to brakes
lee
Old 01-25-2008, 09:31 PM
kmat123's Avatar
Thanks for the info guys! I figured that since I have the drums off anyways I'll get them turned and put in new wheel cylinders too. That rear inner seal is a real PITA to get seated properly!
06-01-2021 01:51 PM
rondogracing
07-14-2015 07:00 PM
87turboPA
07-09-2015 05:58 AM
cyclist231
07-07-2015 12:56 PM
Quick Reply: Rear brake shoe replacement.
