Rear axle shaft year compatible
Old 07-31-2010, 10:11 PM
2fast4me's Avatar
123456
Old 08-01-2010, 03:24 PM
MudHippy's Avatar
You should be able to use most 86-95 rear axle and brake assemblies. I don't know for sure if the ones with ABS would work. But I'll bet they're pretty much the same as the rest, and probably would. I do know for sure that the 4x4 rear axle shafts themselves are all the same from 86-95. But as for the brakes, 4Runner's use larger brake shoes, but in the same size brake drums as pickups. So you can just swap the shoes and drums depending on what you find and which you've got. Make sure you keep the drums and shoes matched up, don't try using the larger/wider shoes in a drum that had the smaller/skinnier shoes originally, or vice versa. You'd need to get the drum turned before you should do that.
Have fun!
06-01-2021 01:51 PM
MMA_Alex
25
04-18-2017 05:07 AM
lledwod
08-30-2016 01:03 PM
Avenged
07-09-2015 07:55 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: Rear axle shaft year compatible
