Rear axle locking after being in 4x4??
Old 07-13-2012, 12:25 PM
ToyYoda's Avatar
Question Rear axle locking after being in 4x4??
I have an 87 4runner 22re. Here's how the problem is caused. My truck drives just fine in 2WD and never have a single problem. When I decide to take it offroad and put it in 4WD, the hubs lock and goes into gear as it should, no problems there. I'm also able to unlock the hubs and drive home just fine.
The weird part is that once I get home and park the truck, parking brake on of course, the next time I drive go to drive it, the rear axle locks up and I have to wiggle the wheels for a while to break them loose. Both passenger side and drivers side wheels have to be broken free before I can drive; Then it's back to driving just fine with no problems.
I'm confused as to what could be causing this problem and why it's only after using 4WD and being parked.
Old 07-13-2012, 12:31 PM
TNRabbit's Avatar
It sounds like the parking brake is sticking....
Old 07-13-2012, 05:48 PM
ToyYoda's Avatar
I thought that might have been it as well but when I wiggle the wheel, I can see the drum move about half an inch. Maybe the parking brake pressure has been released but the pads at still sticking? Also, why would it only do it after being in 4WD? Or maybe it's the water from the creek causing the parking brake to stick?
Old 07-13-2012, 05:54 PM
shakes_24's Avatar
Do you drive in mud/water when your Offroad? Probably just you pads sticking.
Old 07-15-2012, 05:59 PM
ToyYoda's Avatar
Yeah, I did drive through some water. Mud as well.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
ItsJustD
07-07-2015 07:49 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Rear axle locking after being in 4x4??
