rear axle bearing...
Old 12-12-2008, 10:54 AM
elnino's Avatar
well i searched and it said i had to remove the third member,axleshaft..and well....change the bearing...is just that? or is it there more to that?
Old 12-12-2008, 11:04 AM
tc
tc's Avatar
What rig?
No, you don't have to remove the third if you're talking about the outer bearnig on the axle.
You will need a BEEFY press with a long throat to press the old bearing off and the new bearing on.
http://personal.utulsa.edu/~nathan-b...33rearaxle.pdf
Old 12-12-2008, 11:34 AM
elnino's Avatar
94 pick up ...yeah the outer..
Old 12-12-2008, 11:53 AM
tommy316's Avatar
I just replaced this a couple weeks back. Couldnt figure out a way to get the old bearing off so just broke out the torch. Used a 20ton press to get the new one on, just make sure you do it in the right order. I think we ended up using a large socket to help press the bearing in. It can be a PITA. Remember to replace the oil seal while you are in there!
Old 12-12-2008, 07:34 PM
elnino's Avatar
do i have to remove the third member?
Old 12-12-2008, 07:55 PM
tommy316's Avatar
nope, you should drain the oil first though so none spills out.
Old 12-12-2008, 09:13 PM
desertcamper67's Avatar
Or just put your oil drain pan under the backing plate so when you separate the axle from the housing it will drain neatly.
Old 12-13-2008, 01:16 PM
85toy's Avatar
i suggest taking the axle shaft to a shop, should cost about 40 bucks. and do not use a torch on it.
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
yourrealdad
07-21-2015 11:13 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: rear axle bearing...
