rear axel housing
Old 05-12-2010, 02:48 PM
offroad1990's Avatar
rear axel housing
im haveing a small what looks like oil or grease leak coming from my axel housing,, could it be just a loose bolt?? any advice?
Old 05-12-2010, 03:00 PM
iamsuperbleeder's Avatar
where specifically on the housing, in the center near the differential?
Old 05-12-2010, 03:19 PM
yea its like in the bottom center
Old 05-12-2010, 04:23 PM
ah okay
could be a loose drain or fill plug, or a clogged breather, but at worst, it's probably just the 3rd member to diff housing gasket
had the same thing happen to mine
it's fairly common
resealing it can be an entire afternoon's job though. step one would be to drain the diff fluid. then you have to slide the axles out in order to remove the 3rd member from the housing to replace the seal, and in order to do that, you have to undo the brake lines at the wheel cylinders (which means you have to bleed the system once you put everything back together), disconnect the parking brake cable (which involves digging into the brake shoe setup), and then remove the 4 bolts that hold the backing plate to the axle housing, and the axle/backing plate/wheel bearing assembly will slide right out. then move to your 3rd member, unbolt the driveshaft flange, then remove the bolts around the differential, and get read to hoist about 60lbs while laying on your back, lol
then just scrape the old gasket material stuff, apply a new one along with some RTV (a lot of poeple will tell you to just use RTV; my argument to that is, if you're only suppose to use RTV to seal it, then WHY is a gasket offered?), and just put everything back together starting with the 3rd member, then the axles, and the brakes, and refill the diff fluid, and you're on your way
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
deepmarsh
08-06-2015 03:44 AM
andrewtexas123
07-14-2015 04:29 AM
Edionne13
07-09-2015 01:59 PM
Quick Reply: rear axel housing
