Rear Anti Lock light
Old 02-06-2014, 01:09 PM
99SR5's Avatar
Just about every time I drive my truck over 10 miles on the highway the Rear Anti Lock light comes on. The tires are the same size all the way around. Its a very clean truck and seems very well taken care of so im not too sure what to think. I havent looked at it yet, its too cold outside haha. The rear is a little saggy so Im not sure if that would cause it? Has anyone had something like this happen?
Old 02-06-2014, 04:39 PM
Staff
Terrys87's Avatar
I see three different trucks in your signature. Which one you asking about?
Old 02-07-2014, 11:47 AM
99SR5's Avatar
oops sorry. the 94. the others are sold.
Old 02-08-2014, 09:46 AM
kpnalder1's Avatar
Not to hijack this thread but I've got a rear anti lock question as well. My anti lock light works fine as it's not stuck on but every time I get on the brakes hard on a slick surface the rear wheels lock up and never release until I let off the brake pedal. I've looked online and seems the only thing I can find is regarding the anti lock light being stuck on. Where would a good place be to start trouble shooting why the anti lock isn't working? Thanks! I have a 95 4Runner V6
Old 02-08-2014, 07:56 PM
Turbospeed90's Avatar
I have the same issue on my 93. I have flushed the brake system, and I'm talking over-flushed
Old 02-08-2014, 09:04 PM
RJR
RJR's Avatar
Might want to pull the drum off and make sure they're not full of oil from a leaking rear axle seal. Oil in the brakes will make them grabby and prone to lock-up.
Old 02-11-2014, 01:41 PM
99SR5's Avatar
hmm ok ill check that out, thanks
Old 02-12-2014, 07:10 AM
Flash319's Avatar
These trucks don't have sensors at the wheels, the sensor is on the top of the differential. You can pull it out and have a look at it as it might have a bunch of metal slivers on it. That sensor is usually the problem.
I have found that the abs on these trucks is a joke. I usually end up disabling it and ripping the modulator out and put new lines in. Also it is not very smart. Right now I am not feeding the modulator with any hydraulic pressure and it thinks everything is fine.......
Old 02-12-2014, 01:50 PM
99SR5's Avatar
ok perfect, thank you! i wasnt sure if it was like 3rd gens where it has an abs ring on the axle with a sensor or what.
ashersullivan88yota
01-18-2022 05:37 PM
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
Kalihi,HI
07-09-2015 04:29 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: Rear Anti Lock light
