YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-30-2013, 02:26 PM   #1 (permalink)
Personal Sales Rating: (0)
Really odd 4 wheel drive issue.....
Ok s I could really use any help I can get at this point. I just bought a used 1992 toyota pickup, its a 5 speed, 4x4, 22r motor. I put it in 4 hi the other day because there was a ton of snow on the streets, ( it was blowing snow I would say had about 4 inches on the street and maybe a foot every where else.) The truck was really bouncy and did not want to excellerate past about 35mph. Whe I pulled up to a stop light I let in the clutch and took the transmission out of gear and it stopped like I was pressing the brakes, not hard mind you but enough where I noticed. Also I had stopped on a minor incline and it didnt roll backwards at all.... So I put it in 2 wheel and drove home. I have put the front end in the air and both axles and the front driveshaft turn when the truck is in neutral and in 2wheel drive. When I put it in 4 wheel or put the transfer case in neutral I cant turn it, it attempts to turn the rear driveshaft. Nothing seems loose or worn out that I can see. So I am wondering if I have different sized gears front to back or is my tcase shot? Any ideas would be really helpful!!
RGille is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-30-2013, 07:01 PM   #2 (permalink)
Personal Sales Rating: (3)
vasinvictor's Avatar
My first thought was different gears front and back. Do you have locking hubs, or the ADD system? If ADD, you'll have hub plates that lock the wheels to the CV axles all the time, thus your CV axles will turn when, even when in 2wd. If you have ADD, and the front driveshaft is turning in 2wd, you have a problem with the ADD actuator being stuck in the "locked" position. You can manually apply vacuum to 1 or the 2 VSVs on the passenger fender to lock and unlock the front end. That's neither here nor there, just some info you can use to start your search
Of course, your next course of action should be turning the tires and counting the driveshaft revolutions to determine your differenital gear ratio for the front and rear. You can search and find that too, should be easy enough to find.
__________________
-Drew
1995 4Runner 4x4 | 3.4 5vz|a340f auto swap | Inchworm Tacoma Adapter | rf1a gear drive case | 4.10 | Lock Right rear | non ADD front swap | manual hubs | 1.5" 4Crawler BL | 31x10.5 Firestone Destination A/T | swaybars delete | shaved bumpstops
vasinvictor is offline
Old 01-30-2013, 07:05 PM   #3 (permalink)
Toyota~Boy's Avatar
Send a message via AIM to Toyota~Boy
Well said.....
I'd try I bolting other the front or rear driveshaft then turning the wheels to see if its free or still binding. That can eliminate the transfer case
__________________
Old Toyota's Never Die.....
.......They just get Rebuilt......
87 Toyota Pickup, Built 22r 5-speed, 4x4
Toyota~Boy is offline
Old 01-31-2013, 12:51 PM   #4 (permalink)
Threadstarter [OP]
Ya no auto hubs on it. I tried the axles with the driveshafts off so it looks like I am going to be counting rotations. I will let you know what I find!
RGille is offline
Old 02-01-2013, 11:24 AM   #5 (permalink)
Did you check to make sure your front and rear tires are the same size? I know it sounds obvious, but you never know...
__________________
'92 Xtra cab, 3VZ-E, 4WD, 180k miles, pretty much bone-stock
Sturmcrow is offline
Old 02-01-2013, 12:40 PM   #6 (permalink)
Threadstarter [OP]
Ya they match, it is kind of sad people actually dont get that but I have seen it before myself lol..
RGille is offline
Old 02-01-2013, 12:51 PM   #7 (permalink)
I had the same "braking" issue but with a very different solution.
My rear axles seals broke and while fixing it, replaced a bad bearing as well as refilled the differential fluids. I also greased all the U-joints and others joints along the entire system. After both of those, it runs just fine in 4WD.
I'd try this first since it's way easy to do. The lubrication points are recommended every 1-2 years per Toyota. If your differential fluid is low, you could ruin the t-case. I did not have the bouncing issue though so this may or may not fix that issue but helped clear up the "braking" issue.
__________________
'91 Pickup SR5 Extra Cab- 4x4 3VZ-E 3.0L - 281k miles and counting
Gamefreakgc is offline
Old 02-01-2013, 02:06 PM   #8 (permalink)
iliketoyota's Avatar
Mine has always had the rear hop a little in 4wd over 50. Idk if it has different gears or what. I wouldn't think so because its stock. All u joints are good and has brand new tires.
__________________
1987 Toyota 4runner SR5 22re 5 speed All options except power windows
Quote:
Originally Posted by peow130 View Post
I shift when the truck goes it goes "VVVRRRRRRRRRRRR" instead of "woooom"
but inbetween "WHHHAAAAAMMM" and "WHARRRRR" is the sweet spot for torque/HP.
(i dont have a tach)
iliketoyota is offline
Old 02-04-2013, 06:19 AM   #9 (permalink)
Threadstarter [OP]
Ok so its different gears.... Front axle is running 4.30 from an automatic truck and the rear is the stock 4.10. So I am going to order up a new front and rear gear set. Thinking of going to 4.56 as I am not planing on running tires bigger then 31". any other ideas on gear ratio? Want to make sure that I only do this once and get the best ratio in the axles.
RGille is offline
Old 02-04-2013, 06:40 AM   #10 (permalink)
Yamiryder's Avatar
If you can, i would find a 4runner that you can get the rear third and front diff out of. If i have my facts correct, a 2nd gen V6 4runner with an auto has 4.88's and a 5 speed has 4.56's. However, the 4.88's are not capable of being regeared.
__________________
My DD ext. cab build
http://www.yotatech.com/f199/yamiryd...-build-264889/
Toyota Pickup Facebook page! http://www.facebook.com/ToyotaPickups
Yamiryder is offline
Old 02-04-2013, 05:33 PM   #11 (permalink)
BamaYota1's Avatar
If you don't know how to correctly set up a differential, you probably shouldn't try it without help from someone who knows what they are doing. No offense, but I would have torn my engine apart to fix it, but I wouldn't dream of trying to set up gears.
Just be patient and search for the gears you want in a used set up. It could save you a very expensive mistake.
BamaYota1 is offline
Old 02-08-2013, 07:11 AM   #12 (permalink)
Threadstarter [OP]
A friend of mine is a mechanic and knows what hes doing with setting up new gears so I am going to have him help me out. Thanks for all the great input guys I will post my end results and maybe a walk through of the install.
RGille is offline
Old 02-23-2013, 09:30 AM   #13 (permalink)
Threadstarter [OP]
ok so I got it done...... Wasnt pretty and took me a while but everything is setup perfectly!! Just took patience and a little digging through resources to make sure it got done right.
RGille is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
33, 456, gears, tires, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
