Re-Route Evap Vent Line
Old 08-29-2013, 01:09 PM
SacRunner's Avatar
With doing a 3.4 swap and having to use the 3.4's charcoal canister on the driver side, I was able to get rid of the 3.0's cylindrical charcoal canister from the passenger side fender, freeing up a lot of space.
Now the vent line from the gas take that feeds into the charcoal canister is still in the same place: awkwardly in the middle of the passenger fender sitting in the way of mounting something else, like say an ARB compressor.
So, my question to all of you is, has anyone been able to re-route that hard line closer to the firewall?
Can the small hand-held tubing bender used for brake lines be used to bend these lines? Something like: http://www.summitracing.com/parts/oes-25125/overview/
And, if I decide to cut the hard line down on the firewall, is there a tool that will add that "barb" to the end of the line? All I can think of is a flare tool, but I know this isn't a flared end.
This is the hard line in questions (in the yellow circle), obviously before the 3.4 swap:
Thanks
Old 08-29-2013, 01:36 PM
wyoming9's Avatar
Red face
if it is in your way just move it cut it to what works best.
i bet if you posted this in 3.4 swaps you would get all kinds of ideas.
you really don`t need the bell to keep the correct size new vacuum hose on.
Old 08-29-2013, 01:40 PM
totally a bro
Staff
vital22re's Avatar
I remove the mount on the fender and bend the line back and run it along the firewall reusing the mount bracket to bolt up at the old 3.0 evap mount holes.
Old 08-29-2013, 02:02 PM
SacRunner's Avatar
Yeah, I was back and forth for little while whether to post here or the 3.4 swap forum, but settled on here.
Good to know about not needing that little bulb or bell on the end of the hard line.
Vital, the plan was/is to bend the hard line back along the fire wall (hadn't thought about how to mount it yet, so thanks for that idea), but I'm not sure what the best method of bending the tube is: by hand and risk kinking it, or using one of the brake line tubing benders.
Thanks for the input so far.
Old 08-29-2013, 10:29 PM
wyoming9's Avatar
Red face
With old lines like this it might kink or break even with a bender.
They just get brittle with age at least here on the East Coast might not be a issue out there.
Linked2002
3.4 Swaps
7
12-15-2015 01:31 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
this_guy
07-31-2015 01:27 PM
e_richard
07-30-2015 06:50 PM
Quick Reply: Re-Route Evap Vent Line
