Rattle between 1500-2000 rpm
Old 08-06-2016, 10:06 PM
lalojamesliz's Avatar
I have a clicking/rattle near my water pump area on my 87 22r. 160k miles and I just got it.
The rattle goes away after 2k rpm. Can this be a timing chain problem or water pump problem or something else? I'm trying to combine my shopping list for rockauto instead of different orders later on.
Old 08-07-2016, 12:19 AM
miketheband's Avatar
Originally Posted by lalojamesliz
I have a clicking/rattle near my water pump area on my 87 22r. 160k miles and I just got it. The rattle goes away after 2k rpm. Can this be a timing chain problem or water pump problem or something else? I'm trying to combine my shopping list for rockauto instead of different orders later on.
Timing chain , pop the valve cover off and look at the guides see if the one on the drivers sides not broken if so , the chains stretched
Old 08-07-2016, 12:49 AM
Yay
I'm going to do a compression test when I wake up ( I need to go to bed) and if the numbers are good I'll buy the timing kit, water pump and maybe I'll even change the headgasket. Roughly $150 with arp bolts/studs
Old 08-07-2016, 09:32 AM
Just pull the valve cover off and look it's only 4 bolts , ill be doing mine soon too
Old 08-07-2016, 12:28 PM
I just had it off for a valve adjustment...... I need to take it back off to make sure I set cylinder #3 valves good anyways. I just did a compression test and #3 was lower than the rest. I'll post my results
MaK92-4RnR
08-09-2016 12:14 PM
yota81
07-31-2016 06:00 AM
orbt
07-10-2016 10:38 PM
geoduke
05-18-2016 04:18 AM
abby356
05-17-2016 05:54 PM
Quick Reply: Rattle between 1500-2000 rpm
