Raptor engines?
Old 08-13-2013, 04:47 PM
Erik Hinch's Avatar
Raptor engines?
My 86 Runner needs a heart transplant. I talked with Putney at 22REPerformance.com, they have a 8-10week lead time, I can't wait that long. So i found www.raptorengines.com they offer a performance engine for just under 1500. The tech write up seems like the real deal, I spoke with them today by phone, very professional and informative.
That being said has anyone had experience with them, good or bad?
the delivered to me price is $1985 including the core back to them.
TOYOTA 22RE ENGINE HIGH PERFORMANCE 135HP/173FTLBS
Price: $1,495.00
Add to Cart:
Details: TOYOTA 22RE REMANUFACTURED ENGINE HIGH PERFORMANCE / 135HP @ 4800 RPM - 173FTLBS @ 2800 RPM THIS ENGINE HAS THE FOLLOWING: NEW HYPEREUTECTIC PISTONS & MOLY PISTON RINGS. NEW ALUMINUM PERFORMANCE ROD & MAIN BEARINGS. NEW THRUST BEARINGS. NEW OIL PUMP. NEW FULL GASKET SET. NEW TIMING GEARS, CHAIN, RAILS & TENSIONER NEW TIMING COVER NEW BRASS FREEZE PLUGS NEW OVERSIZED VALVES, BRONZE GUIDES & STEM SEALS. NEW HEAVY DUTY HI-FLOW CYLINDER HEAD. NEW COMP CAMSHAFT 260 DURATION-213 AT .050-.430 LIFT. MACHINE WORK Bore and hone block with torque Plate with moly finish. Deck cylinder block parallel to main line with CBN. Re-size connecting rods with new pin bushings. Hang and align new pistons onto connecting rods. Line hone main line. Grind & polish crankshaft. Fully balanced assembly!!! ALL OF OUR ENGINES COME WITH A 7 YEAR / 70,000 MILE WARRANTY!!
THE CORE CHARGE FOR THIS ENGINE IS $500.00
Old 08-13-2013, 05:50 PM
'884Runner's Avatar
Never heard of them and not much about them on google. On an interesting note: if you read the About Us page it reads almost EXACTLY like hiperformer's description of their rebuild process.
Old 08-13-2013, 06:06 PM
Erik Hinch's Avatar
Yeah, I could not find much at all on them. I am clear on the other side of the country from them. I hoped to find someone that had some sorta previous dealings with them.
Ya'll sound off if you have dealt with the Raptor Engines company.
Old 08-14-2013, 08:18 AM
snobdds's Avatar
There is a guy on here that bought one of their High Preformance 3VZ engines that claim to make 190 HP. Search oh hear and you will find it...
I don't like when companies don't list the exact manufacturer of the parts they put in the engines. Most good builders will put they use an OEM head gasket and OEM oil pump etc. Usually this means there using nothing but chineese parts in the build. Then they bore out the block to the max tolerences to get the "135 HP", which makes the block unusalble later on. Most good builders will only bore out to get it strait and nothing more. Then they don't have to use huge oversize bearings to make up for all the material they took out.
Now I went with 22repreformance and had Jim find me a block that only needed honing up to bring it back to square. Then I had my Toyota parts guy send him all new OEM bearings, pistons, etc to make it all OEM again. You can't beat OEM for quality and I've had no issues with the engine.
Good luck.
Old 08-14-2013, 01:22 PM
xylicon's Avatar
Check out Sunwest Automotive http://www.sunwestautomotiveengines.com/
I purchased a 22R from them back in 2011, almost 40k miles on it so far.
Old 08-15-2013, 05:35 PM
Erik Hinch's Avatar
Well got a compression test finally and found I have a burnt valve in cylinder #3. I have a good head from my son's 86 4Runner replacement, Gonna take it for reworking and ordered a 268C/Torkr cam from Ted at engnblder.com, $119, delivered to my door. Can't Wait!
Old 08-15-2013, 06:15 PM
totally a bro
Staff
vital22re's Avatar
Had a buddy who bought one, head gasket popped at 20k.
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: Raptor engines?
