Random squeak?
Random squeak?
Did my IFS 4 inch suspension life 6k ago and I'm now hearing a random squeak from some bolt in the front of the passenger side I'm just wondering what bolt I should check and crank down on.
Double check whatever bolts you had to remove and re-install for the lift, look for any marks indicating that a bolt is moving up and down or side to side (should have some sort of wear around the area.) Or just get some wd-40 and spray each bolt one by one until it goes away then bam you've found your culprit lol. OR you can just re-tighten every bolt on the lift.
nvwiggins
13
06-16-2016 03:05 PM
tazman1972
11
09-28-2015 10:32 PM
