Rain leaking under glovebox while driving
1994 hilux has a drip that occurs only while driving in the rain. It drips on the passenger side, under the glovebox. It just misses getting the ECU wet but the A/C relay catches hell. I've replaced it once. Now I know why it failed. I can't find a leak around the windshield, and it's not condensation from the A/C. Has anyone had water coming from inside the fender well?
Staff
Look inside the cowl in front of your windshield and see if there is alot of debris there. I seen one with a rust hole from trash sitting there. You will need to remove your wiper blades to remove the cowl.
These trucks are known for getting rust around the windshield. I had to have a windshield pulled and cleaned the channels where it sits and seal it up to fix it.
Hey thanks to all who offered advice last week. I took off the cowl and saw a twisted looking area of the windshield gasket I used some clear spray sealant with several passes after dry each time. No more leak!!
I really appreciate all of you and how willing everyone is to help.
Kluch8651
07-09-2015 10:39 AM
Avenged
07-09-2015 07:55 AM
