Radiator replacement
Old 12-21-2009, 12:11 PM
mlrtime99's Avatar
Have you guys have any experience with aftermarket radiators? My OEM mounts cracked, cskauto shows a ready-rad 432272 and a Spectra CU-50 for 4x4s. I've heard bad things about ready-rad quality but it's a single row alum/plastic radiator with 1" depth while the Spectra is an 1.25".
Anyone have any feedback?
Old 12-21-2009, 12:19 PM
MaK92-4RnR's Avatar
I need one as well. my OEM mounts are fine, but the top of mine has 4 pin hole leaks. I was screwing around and looked at the LCE engineering radiator... 600 bucks, fully aluminum. REALLY expensive but is a gem.
Old 12-21-2009, 12:28 PM
mt_goat's Avatar
I'm running a aluminum/plastic tank one row radiator I got from Summit. No problems yet...knock on wood. It seems to cool better than the 3 row copper/brass rad it replaced, even though its only 1 row. The one row with aluminum is deceiving because its one BIG row. There is actually more core to fin surface contact than the 3 little rows. Plus the coolant flows better with one big row.
Old 12-21-2009, 12:29 PM
badattitude's Avatar
I've heard others on this forum recommend KOYO. This is what I'd get.
http://www.go-part.com/9602-toyota-4...8-p-23842.html
Old 12-21-2009, 12:34 PM
mlrtime99's Avatar
Right now I'm looking for a cheappy OEM equivalent, if I ever go the V8 route I'll go the full radiator big money route.
Old 12-21-2009, 02:50 PM
InternetRoadkill's Avatar
I think mine came from "radiator barn" (???). Maybe. It was a couple of years ago. I bought a V6 radiator for the 22RE and it's working wonderfully and wasn't all that expensive.
Old 12-21-2009, 03:50 PM
1990yota-pickup's Avatar
where is the hole at? fix it...
Old 12-21-2009, 06:19 PM
Junkers88's Avatar
I bought an OEM from Napa for about 60$. Bolted right in, no issues.
Old 12-21-2009, 07:21 PM
GenXr's Avatar
Good info in your post. Thanks. I may just go with a single row type from OReilys.
Old 12-22-2009, 10:16 AM
thats not a bad price...
Old 12-22-2009, 10:37 AM
OrRunner's Avatar
replaced mine with a copper and brass one from a local shop. I personally am not a fan of a plastic and alum. ones. I went in with the my mind made up that i was getting a copper and brass replacement but he also offered the other. The guy at the shop told me that the alum does not absorb as much heat from the fluid as the alum. I can not confirm that, but i know a few people running the plastic and alum. ones with no problems and they are about half the price. 80-120 or 220 for brass and copper.
Old 12-22-2009, 11:22 AM
Tracey98277's Avatar
i have the ready-rad and i like it, it mounted super easy and works great with absolutly no leaks.
Old 12-23-2009, 09:11 PM
MaK92-4RnR's Avatar
so no one has complaints of using one from radiator barn? Its 157 bucks and I need a new radiator. its also a three row which is what i'm wanting. anyone have any objections?
Old 12-23-2009, 09:24 PM
flyingbrass's Avatar
I bought a 3 row CSF from Radiatorbarn a couple years ago. It works, as in it fit, cools well and doesn't leak.
The drain plug is a pain if you're used to the nice downspout on OEM radiators. Instead of having a tube to direct the coolant down into a bucket as you back the plug out, it just sprays out everywhere as you loosen it, then shoots out rearward.
Old 12-23-2009, 09:26 PM
MaK92-4RnR's Avatar
^^^ rofl... what if I took the plug off the OEM and put it on the one from radiatorbarn? do they have the same fittings?
Old 12-23-2009, 09:44 PM
It's a different setup. Toyota had a horizontal extension with an outlet at the bottom. Back the plug out and the coolant would run down through the tube. Very nice. CSF has a plug screwed into a hole. Loosen it and coolant sprays out everywhere around the sides until the plug is completely out, then it shoots somewhere near your front axle. Have fun draining any coolant if you're trying to save it.
Old 12-23-2009, 10:16 PM
MaK92-4RnR's Avatar
lol /sigh. we'll see what I can do i guess. thanks
Old 12-23-2009, 11:04 PM
You asked for complaints. I gave mine. I'd probably buy the same radiator again. Just saying don't plan on easily saving your coolant if you need to drain some. Toyota Red costs $25+ per gallon.
Old 12-24-2009, 05:14 AM
thats why you go to dollar general for a bunch of cheap cookie pans.. to collect all that coolant..
Old 12-24-2009, 06:20 AM
shaeff's Avatar
I got one from my local radiator shop. It's probably 2.5-3" thick. It's great quality, and there's no plastic on it.
Quick Reply: Radiator replacement
