radiator leak
radiator leak
So after visiting a mechanic to have my AC looked at, he also noted that my radiator has some small leaks.
He said that they could either repair the radiator (cost of $240) or replace it ($280)
However, I haven't noticed any problems with overheating issues in the past 6 months I've owned the truck. I have had to add a bit of coolant though, as I noticed the levels dropped a bit.
So, I have a few questions...
1. Should I fix the radiator? Or will it be fine so long as I keep an eye on the coolant level?
2. Will some of that radiator leak stopping fluid work? http://www.barsproducts.com/C16_R6.htm
3. If I replace the radiator, is it a hard job to do yourself? I'm just getting into auto repair, but feel pretty comfortable with a wrench now. Is this a job that I can tackle myself? I would also need to replace the hoses and thermostat as well.
thanks for all the input!
You can pick up a new 3-row radiator in the $100-$150 price range from a number of on-line sources and it is easy to replace yourself. Just drain the old one, pull the hoses, 4 bolts hold it in place, and it'll lift right out. Drop the new one in and fill it with coolant and it is good to go. Usually costs about as much to repair the old one as to get a new one.
- http://www.4crawler.com/4x4/ForSale/...ToyotaRadiator
I've got similar leaks on the top of my rad and plan on replacing it at some point. I figure its from corrosion caused from the antifreeze being old, and acidic. If this is true then how long will the rest of the rad last if the holes are repaired? One of these days I'll get around to testing the PH of my antifreeze...
sounds like doing the repair myself is the way to go. Realistically, how long can I go without repairing it? I know it'd be best to do it ASAP, but there is a list of things I need to repair on my truck, including a leaky seal on the t-case/rear driveshaft and I'll be needing to replace all 4 brakes soon.
So my question is, how high do I need to prioritize this radiator problem?
Lets put it this way. If your radiator blows a big hole you'll have a major problem if you try to drive it anywhere. Have a backup plan if you want to go out of town with your rig. I've had the holes in mine for about half a year now and they have gotten a little worse, but still seems to hold strong. Like others have said, keep it topped off.
I have repaired my radiator 2 times now using the prematex epoxy I have a small crack on the top passenger side .
I sanded it down to bare brass then hit it with a rough file and put a dab of the permatex epoxy over the crack.
I used the 4500 PSI epoxy ans it held for 9 months I figure that if I only have to put a dap of the epoxy the size of a quarter on it every 9 or so months it is way cheaper then buying a radiator.
thanks for the advice. I just spoke with the local dealership, and they want $469 for a new radiator! Is there anything wrong with the ones you can pick up at Kragen or NAPA? I can find them on those places for under $200.
They are good replacements, I've been buying mine from radiator.com. They will be cheaper and have very fast (free last time I ordered) shipping and lifetime warrany.
Just so you know, if you have to get a new shroud, it's one piece, and you'll have to take the fan off to get it in.
Make sure you tighten up those hose clamps reeeeeeeeal good, I didn't the first time and it never stopped leaking after that, I had to replace the top hose.
Oh yeah, the leak also caused the third belt in to bust, so that was a PITA.
When I did my radiator, my old shroud was one little peice at the top. I replaced it with a new stocker. I didnt have to remove the fan to install it. To remove:
Unbolt shroud and set it over the fan, this will let you lift the rad out of place.
To install put the shroud over the fan, out of the way and drop the rad in. Easy peasy
