R150F Upgrade
R150F Upgrade
Am I correct to think that this
http://www.marlincrawler.com/transfe...ine-input-gear
makes the R150F have a 23 spline output to the t case like the R151?
Also, does the R151 share a common bellhousing with the R150F?
No. The R150F already has a 23 spline output.
The 23 spline input gear goes into the gear drive transfer case to either replace a 21 spline or upgrade an existing 23 spline to Marlins total-spline.
To answer your second question... The R150F bellhousing mounts to a 3VZ-E while the R151F bellhousing mounts to a 22R/RE. So they aren't the same. But the bellhousing can be swapped between these transmissions.
kawazx636
10-06-2021 03:03 PM
4runnerFireman
09-29-2015 06:24 AM
