r150 into an 86 22re
Old 04-29-2008, 12:01 PM
hillbillydeelux's Avatar
what kind of problems am i going to run into????
Old 04-29-2008, 12:03 PM
Matt16's Avatar
I just read something about this a while ago. Try searching "rebuilding r150" or something.
Old 04-29-2008, 03:56 PM
Luvmeye22re's Avatar
https://eshop.advanceadapters.com/co...562-712562.htm
I believe you will need something like this to adapt the trans to your engine. Another thing to think about is if you want to keep your gear driven case (unless you are automatic or g58 right now) which would be a whole nother adapter and maybe a little crossmember work.
Old 04-29-2008, 07:08 PM
JamesD's Avatar
All you need is a 22RE turbo bellhousing and I think a different clutch disk. All bolt on.
James
Old 04-29-2008, 07:48 PM
just a 22re's Avatar
x2 i was going to say i though it was a bolt and play
JNapolitano
11-14-2019 07:46 PM
ia02
08-20-2015 11:04 AM
mreagen
Engine Swaps
08-04-2015 10:54 PM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: r150 into an 86 22re
