r134a conversion
Old 08-29-2009, 11:41 AM
whutface's Avatar
r134a conversion
Would you just use a regular r12 compressor if your converting to 134a?
Old 08-29-2009, 03:32 PM
turborich's Avatar
Yes sir. You will need to add the proper amount of 134a & compatible oil. If you buy a retro fit kit then you should be good to go. Make sure not to overcharge it as 134a runs at higher pressures than r-12. It would be a very good idea to vacuum (pump down the system before you add the new refrigerant) If you have access to a pump.
justdifferentials
14
06-11-2017 08:36 PM
live4soccer7
05-11-2016 06:52 PM
runnermedic
13
09-21-2015 05:20 PM
highonpottery
09-14-2015 12:46 AM
Quick Reply: r134a conversion
