Quiz of the day - Crazy idle after header and exhaust install
So here's what's go'n on; it's easier to show a video than it is to explain...
[YOUTUBE]http://www.youtube.com/watch?v=QFUoC9M3JLc[/YOUTUBE]
If I had a big cam, this might sound awesome! but I dont
Also, it stinks of fuel when running...
At first I though "Ok, it's runing rough, almost like on only 3 cylinders, but it has no power loss on the road; maybe one plugs aren't firing right or something". So I go to each wire and pull it while it's running. The truck idles worse with each, and I can hear the arcing as I move the wires back, so I know it's getting spark. Obviously it's getting fuel, if I can smell it. But to me, it's almost like it's getting too much fuel? To be honest, it use to do the same thing maybe once a week just out of the blue, but it would do it all of maybe 10 seconds, and then it wouldn't do it again for a long time; but this time it hasn't gone away! It didn't do it at first after the exhaust install; it started doing it after I drove up to the store last night, and I noticed it in the parking lot. At the time I didn't think much of it cause like I said, it use to randomly do it and then go away. But it's been doing it since non stop! It accelerates fine, and doesn't jerk or buck while cruising; it only seems to be effecting the idle. No check engine light, so that test wont do me any good. I checked all of my vaccum line visually and by ear, and didn't find anything; about the only thing more I could do with that is to spray some starter fluid around till I hear it smooth out, if it is in fact a leak...
Now the other thing that crossed my mind was the AFM. Now that the motor's opened up with a 3" intake and the header, no cat, and turbo-style muffler, do you think I need to adjust the AFM a little, maybe lean it out some?
I'm at a loss... I can't find anything...
Dudeo, it sounds sweet, looks sweet (chrome) but it doesnt run sweet...
Maybe you need to adjust the timing since you opened it up some.
My '88 4runner did/does the same thing. It idles like its almost missing on one cylinder, but as soon as I tap the throttle, maybe 100rpm worth, it smooths right out.....then it got a rod knock...
Also, your leafs are really flat
it could be not cause of your recent mods but maybe your cold start injector is stuck on and spraying fuel? hows your gasmileage? can you see any smoke coming out of the exhaust when you drive like black smoke? if so white smoke is to lean,black smoke is to rich and blue smoke is your buring oil. if i were you id go ahead and check your vaccum lines with the starter fluid. then hows your spark plugs when was the last time they were changed and what about fuel filter i kno the filter wont cause it but you never know just start going through what you think it might be and make you a list of things it is not thats all i can help you with im sure abe will be more help than me
I would look at adjusting your afm to match the amount of air the motor can now flow since it has been modified. The other thing to check is your base timing. Any adjustment to air flow can affect it. I can not remember the site I was at but it suggested that anything over 2.5 inches won't have enough back pressure for the low rpm range.
all the answers sound good guys, thanks! but what get's me is why it was fine for a little while, and then it started...
tomorrow after work I'll pull the plugs and look at them, and I'll spray around with some starting fluid to try and find a leak
I'll play with the timing a little bit too, and see if that effects anything
can't tell on fuel mileage yet; I filled up yesterday (when I went to the store actually ), so we'll have to see how that goes.
I tryed just unplugging the cold-start valve cause I suspected that maybe too, but I guess it could be mechanically stuck open, not that it's got a constant signal to stay open
O2 sensor's maybe a year old as well. my old one didn't throw a code when it went, but it made my mileage go to hell... but it otherwise ran fine...
no smoke that I can see, just the smell...
fuel filter probably doesn't even have 20k on it; plugs maybe have 2k on them ( I changed them right before new-years )
and the mention about the not having enough back pressure with tubing over 2.5", well there's also no cat in the system anymore either ( maybe that's what I'm smelling? ), so I don't know if maybe that would have something to do with it... I wouldn't think so though...
and yes, I know my leafs are SHOT, lmao; that's why the WabFab shackles that are 3.5" longer than stock just leveled the truck out
on another note, after it started doing it, I put in some Z-Max ( the fuel and oil additive stuff; the stuff that's like $40 a kit ) that I had sitt'n on a shelf, but so far that has had no effect on the running ( not that I expected a whole lot ), but it was worth a try
oh i didnt read that you didnt have a cat yea the smell id say a good 80percent of the smell you have is not havein a cat it reeks kinda like gas but not really its hard to explain the smell but its very noticeable. and see my thing is if it was the afm casuin the problem it would have done it when he got finished with the exhaust not a couple of days after. have you checked your TPS?
When I re-did my exhaust I bought a test pipe to install instead of the cat. The truck was loud as hell and would start to give me a headache from the gas smell while sitting in traffic. I just swapped in the stock cat and the smell went away and the exhaust note changed dramatically as well. Now it's nice and deep. I still have plans to order a high flow cat but my test pipe just sits on the workbench.
Jason
Jason
that narrows it done more it could be iginition circut,engine coolant temp sensor,fuel pump,fuel pressure regulator,idle air control valve. you could try those and see what you come up with
Jason
Jason
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I know in my 2000 GT it took about a day or two before the computer would register a problem after a modification. I dont know if these computers are like that, but ever since my cat was stolen I have had this rough "cam like idle" however after I drive it for a while it smoothes out and it was like there was no problem.
im not sure about the ECMs on these truck on my last one ford when i put mods on the motor and exhaust i had problems if i had problems right after i put them on i did custom headers and no muffler out the back and with no muffler not as much backpressure so when i let off the gas i heard pops in the exhaust yea the PCM didnt like that i think i went about 3 or 4 miles and the PCM shut more than half the power to the motor becuase it went into a safe mode is what the ford stealership called it
I think the ECM's in these trucks are a little primitive to have that kind of programming though... but I've been prooved wrong before...
like i said not to sure with these truck ive been wrong before too but from what i have read about them the ECMs are pretty good considering how old they are and when they were made my opion of course
holy crap I just thought of something...
there's a good chance the truck's been doing it from the moment I installed the header and everything...
I say this for one reason; it's only noticable once the engine warms up. While it's still cool and the idle's up, it's not noticable.
After I finished the install I started the truck and ran it all of maybe 2 minutes to check for leaks, which wasn't enough time to get to full operating temp. Then when I took it to the store it had plenty of time to heat up, and that's when it started doing it.
Also, the stench from the exhaust may not be a gas smell from too much gas. It's more than likely just because there's no longer a cat in the system.
I think I have some AFM adjusting to do...
but I'm going to try all the little stuff first and see how that works
