Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
#2 (permalink) |
Personal
Sales Rating: (0)
http://www.yotatech.com/f96/sound-insulation-11179/
theres another thread here somewhere with a ton of pics on a 4runner |
#3 (permalink) |
Personal
Sales Rating: (0)
I did some of it. It worked okay, but you really have to go to town with it.
I did strips, but I think the only way to really get it to work is to coat the entire inside of the outer body panels, including the tailgate and front doors. Now, here is the issue with front doors. I had a piece in there, this summer, and it had come loose, but in the heat, the sticky stuff got all goey. It stuck to my window, and it took 2 hours to get it undone. You may want to spray some sort of sealant over the mats after install to prevent that from happening.
__________________
Supercharged 1999 4Runner- Baby Beast 2, the mild mannered build-Link 1987 Mutant 4runner|Slightly Modified|Lacking general build direction|Now on 35's-Parts truck-SOLD 1989 Project 4runner-The Redo-SOLD -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#4 (permalink) |
Personal
Sales Rating: (0)
simple solution pull out your motor and plan a giant redwood instead or install a cool sound system
__________________
88 4.3v6 4runner duals fullwidths and 37mtrs and a happy owner |
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
I was thinking about doing all the exterior body panels with either RattleTrap or edead and then placing a second layer under the interior trim panels. All of the interior panels are off right now so installation would be very easy.
One thing I've noticed is that this stuff isn't cheap. Dynamat is horrifically expensive. |
#6 (permalink) |
Personal
Sales Rating: (0)
Dynamat is great stuff. You'll pay for it though.
Your plan sounds good. I doubt it will be silent, but it will be quieter.
__________________
#7 (permalink) |
Personal
Sales Rating: (0)
I've noticed with my 2nd gen, that most of the road noise comes from in the back, inside the quarterpanels where the rear speakers are. Maybe some sort of soft rubberized foam stuff would work there. You won't ever see it, so if you want a less expensive dynamat alternative, that might work. I'm not sure what kind to use, but maybe some hurculiner would work back there.
__________________
1994 Toyota 4Runner SR5 4X4 221,500 miles and counting 3.0 V6, 5 speed 10/15 MPG city/hwy(with 33's) Current Mods Headers, 2.5" Flowmaster custom exhaust, K&N FIPK KC Daylighters, electric fan Ranchos x4, 2" Lift Downey coils 33-12.50 M/T's, 1" t-bar lift, 1" body lift Tow pkg w/ lighthookups Silverstar Headlights, Pioneer Deck w/XM Brushguard 250Watt JLAudio 8" W3 Sub Future Mods
12V Aux outlet-400/800peak inverter roof basket/lights Air locker 4.88 gears H.O. Alternator |
#8 (permalink) |
Personal
Sales Rating: (0)
[OP]
Does the spray-on /brush-on sound deadener do much? It offers rust protection on the inside of the quarter panels unlike the stick-on stuff which might trap moisture underneath.
#9 (permalink) |
Personal
Sales Rating: (0)
There used to be this stuff called "Brown Bread" but it looks like they changed to a new design/name called "B-Quiet Ultimate"
Cheaper then Dynamt http://www.b-quiet.com/brownbread.html My buddy used Brown Bread on his Talon and it made huge difference. I would imagine the new stuff would only be better..
__________________
-Ben '87 4Runner, Turbo'd 22RE, CT26 @ 15psi, Worked Head/Cam/Valves, FMIC, 450cc injectors, MegaSquirt, SS IFS Truss, Manual Hub swap, 4.88 gears, Rear ARB, Front TruTrack, OME Shocks/Leafs, 1.5" BJ Spacers, 33" TrXus on black ProComp wheels. |
#10 (permalink) |
Personal
Sales Rating: (0)
my cousin did his 91 explorer with Dynomat, top to bottom, front to back, everything was taken out and covered and i mean EVERY SQUARE INCH was done, and MAN what a difference! i was going to do it but it significantly adds a
load of weight! but it makes the world of difference! i'm not sure about the fiberglass top on 1st gen 4Runners. and my cousin was into the bass competitions for awhile, with 4 14" JBL 1000W subs in a custom enclosure, it was recorded that his decibals hit 3 lower than a Jet Engine!!!!!!!
__________________
1993 Toyota Hilux King Cab, 4WD, 5VZ-FE, 305,000KMs, 1" lift blocks w/ heavy duty springs, Altezza Hilux tail lights, Crystal Clear Hilux corner and bumper lights. K&N drop in filter, ISR Mod. Husky Liners. 1993 Ford Ranger STX, 4WD, 4.0L V6, 265,000kms. Bone stock DD. NEVER QUIT
#11 (permalink) |
Personal
Sales Rating: (0)
yes i truely does, i did my cargo area inside and out, and the road noise is considerably less, i just used that rocker guard
__________________
#12 (permalink) |
Personal
Sales Rating: (0)
[OP]
How many square feet of stuff does it take?
#13 (permalink) |
Personal
Sales Rating: (0)
I just put dynomat in my front doors and noticed a considerable difference on road and exhaust noise. The music is much more enjoyable now.
__________________
1990 4 Runner SR5 V6 119k rebuilt, brush guard,K and N, piaa fog lights, 31-10.50 Firestone Destination, upgraded 4.10 to 4.88, Detroit true trac in rear. |
#14 (permalink) |
Personal
Sales Rating: (1)
Lowe's sells a product called "water & ice shield" made by Grace.
You can purchase a whopping 108 Sq.Ft. roll for about $80. Compared to Dynomat and other brands, it's practically the same thing but per dollar, you get 3x's the amount. The stuff is thick, flexible, and super sticky. It works a lot better than i expected. My inside doors are getting covered with it and i'll still have enough to use on 2-3 more vehicles...
#15 (permalink) |
Personal
Sales Rating: (0)
[OP]
I've read about the Lowe's soundproofing, but there are two concerns that keep re-appearing. The first is the smell and the second is that the stuff melts in the hot sun.
#16 (permalink) |
Personal
Sales Rating: (0)
I did the ice & water shield inside the doors, as well as a liner for the back of the cab (mine was just bare metal when i bought the truck) It cut down the noise a lot.
the stuff will smell tarry for about a week. i put it in in the summer and didnt have any issues, other than the fact that it's hard to keep it from sticking to itself so it's probably better as a 2 man job, or using relatively small sheets. |
