quick timing question
Old 12-06-2008, 09:34 AM
cpizzle42's Avatar
On my 1994 4Runner with the 3.slow, if my two upper cam gears are both on the timing marks, and the crank pulley is on the 0 degree timing mark, its eveything good?? My belt was loose while the engine was started and the belt skipped a few teeth some where...see link to different thread....https://www.yotatech.com/forums/f116...ic-fan-160906/
Old 12-06-2008, 11:25 AM
tc
tc's Avatar
Yep - but I would put on a new belt and water pump while I had it all apart!
http://personal.utulsa.edu/~nathan-b...67timingbe.pdf
Note the 3VZE is non-interference, so you didn't trash the valves.
bigjstang
08-25-2021 12:41 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: quick timing question
