quick rear bearing help
Old 05-31-2012, 05:24 PM
captainslow's Avatar
One of my rear bearings went out a few days ago, finally got around to taking it apart and it was disintegrated.
Going to a machine shop tomorrow to get the new ones pressed in, but I'm still a little confused.
There is no inner outer bearing? Just one per wheel, and they come pre-greased from toyota?
I picked up all the stuff I need from Toyota, they look like I don't need to pack them, but when I pulled out one of the axles it looked packed (the old non-disintegrated one), as there was lots of axle grease on and around it...
What am I missing here...?
I'm assuming I don't need to pack them, and there is only one per side, instead of a usual inner and outer. Correct?
Old 05-31-2012, 05:59 PM
donomite49's Avatar
sealed bearings cannot be re packed. 1 bearing 1 seal per side.
Old 05-31-2012, 06:01 PM
Thanks that's what I figured.
Old 05-31-2012, 06:07 PM
waskillywabbit's Avatar
Look at the writeup on this topic on 4x4wire.
:wabbit2:
Old 06-02-2012, 02:18 PM
:wabbit2:
I read that before posting, as well as many others. I have never used sealed bearings before. New to me.
What I don't get at this point, is according to the FSM, I have an ABS speed sensor, but I don't have abs, because my axles done have the extra gear thingy on them
What gives?
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: quick rear bearing help
