Quick questions about A/C and heat
Old 02-19-2016, 06:55 AM
Tommy T.'s Avatar
What does the relay behind the climate controls actually do?
I have an 88 p/u and that relay is missing. The truck has the A/C components, but it's all crapped out and I'm not restoring it at the moment. I am trying to get the heat hooked back up correctly. Right now it's running at high speed off an aftermarket switch installed by previous owner.
Anyway, do I need that relay for any heat functions?
Old 02-19-2016, 10:32 PM
Staff
Terrys87's Avatar
I am not sure what the relay actually does but it is needed for it to work correctly. The wiring for the climate control separates easily. I would get one from a bone yard and put it back to way the factory had it.
Old 02-20-2016, 07:08 AM
mct75's Avatar
Well, I know the heat is fully mechanical, IE the lever opens up the valve for coolant to flow into the heater core. I would guess that the relay energizes the compressor clutch for AC. I don't have AC so I'm not sure.
DOK
04-09-2017 06:02 AM
Colton 0716
02-22-2016 01:45 PM
dbowlr
02-15-2016 11:34 PM
highonpottery
02-15-2016 08:22 AM
77RogueRunner
02-14-2016 07:06 PM
Quick Reply: Quick questions about A/C and heat
