Quick Help!
Old 05-02-2007, 06:26 PM
dmon's Avatar
Quick Help!
ok i dont really have time to search, but i just did a valve cover change, and intake manifold change on my 91 p/u v6 4x4. connected everything, and started the motor. it starts normal, but right after it goes "vroom" it dies... it starts up perfect, but dies 1 sec after. but i can hear it still trying to turn, it diesels a lil bit. need quick help. and i check all vacum and all lines 3 times. and tightned the manifold bolts jsut to make sure. thanks!
Old 05-02-2007, 06:42 PM
ChickenLover's Avatar
Are you sure your timing belt didn't skip any teeth while you were changing your intake manifold?
Old 05-02-2007, 06:44 PM
dmon's Avatar
umm, no. it didnt go through there. only vacum wires, and some radiator fliud hose or something was connected to the intake mani. and the gas line hooked up to the mani also... oh and i only removed the manifold
Old 05-02-2007, 06:48 PM
gonzo's Avatar
Is your AFM plug on all the way. Don't ask me how I know. LOL
Old 05-02-2007, 06:50 PM
You have your intake component terminology confused. You can't remove your intake manifold without messing with the timing belt. There are no vacuum lines on your intake manifold. You are either talking about your plenum or your throttle body.
Do you have your intake hoses in place? The ones that connect the afm (at the air filter) to the throttle body...
Old 05-02-2007, 06:51 PM
dmon's Avatar
whats afm plug?? all i know is i plugged in all of the vacum, pvc, gas, radiator line/ hose all in. the truck starts up normal, but a sec after it starts it dies, but still tries to stay alive, you can feel the motor still turning. and if i start it and rev it b4 it dies, it stays running, but if i dont rev, it just die out
Old 05-02-2007, 06:54 PM
dmon's Avatar
ok my bad!!!!! the air intake chamber!!! lol. sorry bout that.
Old 05-02-2007, 06:56 PM
dmon's Avatar
and yea i got everything connected in place. i have another same exact truck, so i know its in the right place... dammit never thought it would end up like this thanks
Old 05-02-2007, 06:58 PM
You'll probably be better off just posting a few detailed pics of your engine bay. If you have something crossed up, someone here will be able to point it out.
Old 05-02-2007, 07:28 PM
dmon's Avatar
so a vacum line pluged in the wrong place can make the motor die right after starting?
Old 05-02-2007, 07:56 PM
dmon's Avatar
ok me and my dad has been working on it. we looked at both trucks, and matched it up. could it be that we put the gasket maker on the intake gasket, so when we start the motor, it got sucked up? we tried starting it up and it starts, but you know when u start the car has a vroom, then when it goes to idle, the truck dies. feels like were almost there, but still missing something... or does the bolts for the valve cover has to b a certain torque? because we dont have a torque ranch, we just made it finger tight. thanks for any input
Old 05-02-2007, 08:38 PM
MudHippy's Avatar
Valve cover bolts are around 14 foot pounds. I've had crossed up vac lines do exactly like your talkin'. It could be some gasket maker gone haywire, I would never recommend using it on any intake gasket, they make some types of very thin film gasket sealers that might be appropriate. I just use the gasket, nothin' on it, works good for me. You could also have a vacuum leak, or a plugged vac line/port.
Old 05-02-2007, 08:40 PM
dmon's Avatar
ok found the damn problem. the stupid airbox tube cracked. so i guess when we started the truck, it sucked air through the crack, and the sensor ine the airbox couldnt detect anything, so yea engine goes poop... now works great thanks for all the help!!
Old 05-02-2007, 08:47 PM
MudHippy's Avatar
Haha, vac leak. Didn't need my help though. A little too late it was.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
zytra
01-24-2019 03:16 PM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: Quick Help!
