Question regarding 3.0 engine
Old 11-05-2007, 10:44 AM
nm4runner's Avatar
Question Question regarding 3.0 engine
just a quick question. My wife who gets to drive the 4runner called me to tell me the truck was hesitating pretty badly and lurching. she was out with the kids and wasnt happy. all the guages read correctly. i had her put oil in the truck and that seemed to help. could it have been low on oil and are those symptoms of that or bad gas or needing water(she put water in the overflow since there wasnt any.)
Thanks for help guys...
954runner
3.0 170something thousand miles.....great truck
Old 11-05-2007, 04:03 PM
nm4runner's Avatar
did some stuff
changed out air filter and cleaned throttle body. seems ok, also filled up with new gas. could any of those problems caused the hesitation
Old 11-05-2007, 04:09 PM
nate V's Avatar
If you are adding oil and coolent that is not a good thing.
There is a possibility the the head gasket went on the engine.
Let it go for a while and see if it needs more coolent or oil.
Old 11-05-2007, 09:28 PM
idanity's Avatar
to run correctly you need
1. air
2. fuel
3. spark.
and if anything is bad, car wont go.
varnish on the throttle body is a likely candidate, but the air,fuel filters are more likely.
regular maintenance and you sound fine. bad gas is also possible. also, water in the tank is possible too.
bigjstang
08-25-2021 12:41 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Roger Borba II
07-09-2015 05:05 PM
Cplmike
07-08-2015 08:47 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: Question regarding 3.0 engine
